On Heather's Workbench - going wide
Heather Kay
I gave myself most of the weekend off, but that hasn't prevented a case of the galloping lurgi striking. I'm not that ill, oddly, but the sore throat and congestion is making me feel a bit spaced out.
Not helped by paint fumes, I suspect.
Probably not the ideal day to be working on the coach livery…
Heather Kay
Slow and steady, recovering from this damned cold in between.
The mouldings are now black, and the cream panels have been carefully retouched by letting diluted paint run around the edges to give the rounded effect. I've painted and mostly lined the S6 door vents, which will be glued onto the body once the lining and other details are complete. The door and window frames need sorting out, too.
Not far off the dreaded lining now!
Heather Kay
Seriously, this damned cold is getting on my nerves. It simply won't shift, and just when I think I'm getting better it comes around for another go. :headbang::'(
Anyway, I have to drag myself from my sickbed and get these coaches moving if the client wants to take them back home to Oz after the family trip to the UK soon. So, with Lemsip and hot water bottle on standby, I finally managed to get some progress on the S6 underframe.
First, I realised the suspension unit etches blocked the buffers, meaning it would be pretty difficult to engineer any form of springing. Out with the hotting stick and a bit of Dremel work, and reattaching things later, here's the mess. I also opened up the coupling slot, which I really should have checked before fitting the headstock. :oops:
In one of those chicken and egg - or should that be cart before horse? - moments, I realised the spring and axle box details really needed to go on before I began the brass knitting of the brake rigging.
Each set is a spring, axlebox, and a pair of J-hangers. The cast whitemetal was quite soft, so I had to be careful with the latter. If you recall, the springs had drop-wires, intended to represent the way they are supported by the J-hangers. Obviously, they would get in the way unless the hangers were drilled out, but some had already been snapped off or mismoulded, so I took the pragmatic route and removed them entirely. As the ends of the springs all but sit on the hangers, you'll never notice.
All the parts were low-temp soldered to the brass chassis. With no location marks, working out where the hangers fitted involved a bit of test-fitting and guesswork, hoping they wouldn't accidentally coincide with etched bolt detail. All was well.
I did make a start on lining the bodies yesterday, but it didn't quite go to plan. I have acquired some acrylic artists' ink, going by the name of Manuscript, which has supremely fine gold particles suspended in the medium. If I can get it to flow nicely from the bow pen, or work in a Rötring, it'll look fab. If not, it'll be the orangey-brown enamel fallback.
Today, though, will be the brake rigging and headstock detailing.
Scale7JB
All brilliant as ever Heather..!
Chin up and soldier on.. Just don't go down the hot toddy route, that's never going to help your lining..! ;)
JB.
Heather Kay
Thanks, JB. Happily, I seem to be fortified by a rather nice fruit cake Best Beloved brought home the other day. Does wonders for the waistline!
The S6 kit includes cast whitemetal buffer housings which need to be drilled through. The buffer heads appear to be nickel silver, turned and then rather bizarrely plated to resemble chrome! Nothing touches the surface, so once I had glued them into the length of thin-walled brass tube that constitutes the shanks, I span them in the whizzydisc with some emery to get back to the base metal.
I held the castings in a pin chuck, taking care to try and seat each one as concentrically as possible. I ran through with a 0.9mm drill, followed up with a 1.6mm drill which gave a nice sliding clearance for the buffer heads.
Thoughts had formed on how to spring the buffers, with consideration given to a wire passed through the back of the coupling hook, fixed into slots at the end of the buffer shanks. It seemed a good time to fit the coupling hooks before attempting any spring work
As you can see, I have adopted a scheme where the couplings are sprung near the centre of the underframe, with a wire hook to each cast hook. The idea is the drag forces will be passed along the couplings, rather than concentrated at the headstock under a "normal" hook-with-spring scheme. It probably makes no real difference, but I went with the gut feeling on this.
I fitted the buffer housings, glued into their holes, aligned and square as best as I could manage. Then I tried to work out springing them. I cut a slot into the end of each ram, intending to glue or solder some wire in place. This would pass through another hole in the counpling hook, because it was in the way, I suppose. Anyway, it didn't work. The buffers didn't have any real spring to them at all.
Apart from the fact the wire had to be passed through various passageways in order to slot into the space, there just didn't seem to be enough gap between the back of the housing and the remains of the suspension unit etch. After some half-hearted fiddling with proper springs, with no real idea of how to fix them in place or return the buffer to the normal position, I took the step of carefully dismantling the whole buffer thing altogether.
I will be ordering a set of the buffers from Slater's which I used on the PLV. They are brass housings, with springs and nuts to retain the buffer heads. I may have to fill the holes in the headstocks, though. We shall see.
Not much to show for the brake rigging, or lining. Perhaps tomorrow will be a better day.
Heather Kay
Today I ordered the replacement buffers, and a set of standard gauge wheels for the V13 PLV which will begin construction eventually.
After a while fitting the screw couplings and the safety chains to the S6, I decided I needed some new vistas.
A gathering of tiddley peeps, having been assembled and fettled, destined to ride some GWR broad gauge stock. They need a base coat, then I shall spend a happy few hours applying colour.
When you begin to look around, it is quite surprising how few seated figurines are available. When you factor in period, the list shrinks still further. The trick will be to find a way to avoid the same figures appearing too close to each other, with a sprinkling of other manufacturers' products to help. These, by the way, are S&D Models Phoenix 43 castings in the finest pewter.
Heather Kay
I nearly cracked the gold lining. I found an elderly Humbrol tinlet purporting to be metallic "brass". The particles are very tiny, and it flowed nicely on the pen. It's the tidying that takes time.
Meanwhile, trying to fit the S6 body to its underframe is a conundrum. I think it needs a bolt or two.
In case you aren't aware, with the narrow body on wide underframe, the whole top of the frames was boxed in to form a wooden step area. Happily, this will hide some nastiness on the solebars on this build…
Well, this is where I've got to. I'm pondering the idea of fitting the top step boards to the body, so the whole unit slots over the underframe as one. This would help to keep the body centred across the width, too.
While I let that idea simmer on the back burner, I shall think about painting the figures.
warren haywood
Heather , wait for the gold to dry a bit then use a cocktail stick to scrape it away. If it's still wet the particles will spread around leaving a metallic smear which is a sod to remove
Heather Kay
Thanks, Warren. That's pretty much what I'm doing.
Meanwhile, the body fixing with the top footboards idea has taken root.
The idea here is the top board assemblies, to which I have soldered a length of wire to represent the lip of the step, will be fixed to the body itself.
In this view, you can see the three holes in each end, which are supposed to be used to fix the body to the normal narrow chassis. By fixing the steps to the body, I can move the fixing points to between the axles, where nuts and bolts won't interfere with brake rigging and suspension.
So that's the plan for the afternoon.
Heather Kay
Fettling, fettling, fettling.
It takes for ever to line out carriages. I hate it, if I'm honest. Okay, it doesn't look that bad, but it's not perfect dammit!:headbang:
Anyway, a little more gold retouching, a little more black moulding retouching, a little more panel retouching, and then perhaps I may get a chance to try the eighth-inch brown lines an inch inside the edges of the cream panels… :confused:
Between bouts of lining, I am in the process of painting the passenger figures. I spent a nice hour or so yesterday researching late Victorian fashion and clothing colours. The figures are more Edwardian in form, but suitable colours and the fact they will be inside the coaches will hopefully give the right impression.
It takes for ever to line out carriages. ... Okay, it doesn't look that bad, but it's not perfect dammit!.
The lining looks neat and tidy to me. I shall be happy if I ever achieve the same standard.
As for the little peeps painting, I intend to learn and benefit from your work in this matter.
Heather Kay
I certainly am, Paul!
I'm hoping the fact the models will be finished to "cared for but tired" finish will let me get away with some things.
This was built about twenty years ago by a mate, but I'm not sure who did the paint job on it.
Until today I had seen only one other example of the brown lining in 7mm so not a common feature. As you say that the model was built about twenty years ago then there is a fair chance that the lining was done by Brian Badger.
OzzyO
I don't think that it's the same coach, as one has six wheels and other one has only four.
But it could be the same painter,
OzzyO.
