Rob Pulham
That is fantastic, thanks Adrian.
I should add that the motion plate and brackets on the ends of the slide bars and also the weigh shaft with the lifting links had to be scratch built as these are not produced by Laurie
. I don't mind scratch building bit's but getting more from Laurie can only be goodA brave man.Hi Steph
I'm considering using Loctite 638 for the assembly of the cranks on to the axle for my latest inside valve gear.
Yep - it's still as sound as it was when I made it and I'm intending to continue using it for all future builds.Hi Steph
A year or so down the line, are you still happy with Loctite 638 as a suitable adhesive?
Nope - it seems to be thixotropic (as most retainers are) so won't flow.How do you apply it? Assemble everything then glue, allowing capillary action (how viscous is it?) to draw it into the joins?
Yep. I clean all the parts and then dry assemble the parts, including a pin through each crank. Then remove one pin and crank, apply Loctite adjacent to the webs. Rotate the crank to smear the retainer and then push it home, followed by the pin.Put some on and the add the part?
Typically around 30 seconds. It apparently reaches the same strength as Loctite 601 in about 2 minutes.How much adjustment time do you have?
Not really....A brave man.
Steph, if the Loctite 638 is good enough and you follow the stringent cleaning regime... then why do you need to pin the joint?
Why not make the joint a reasonable fit and then insert a taper pin?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
