A G3 micro layout.
Discussion in 'G3' started by geoff_nicholls, 12 March 2020.
  1. geoff_nicholls
    geoff_nicholls Western Thunderer
    First test assembly of the boards for my new layout replacing Aldeburgh Harbour. 3.4m long, 750mm deep. A sector plate feeds the main(platform) line, a run round/siding, and a wharf siding with a switch back siding in front of the sector plate. At the opposite end another sector plate allows the locos to run round. The cutout is for the wharf. A shop from Rundle stands in for the station building.
    The line from the wagon turntable will cross the main lines to reach a low relief goods shed at the back, as happened at quite a few ECR/GER/LNWR stations. If, as is hoped, the layout is eventually exhibited, I plan to substitute a 1.2m sector plate for that small one on the left, and run it as a through station. The station buildings and infrastucture will be interchangeable for running Early or Pre-grouping stock of the above railways.
    Next test is to try and fit the scenic section of Rundle in the room with it.
    Peter Cross, unklian, P A D and 9 others like this.
  2. Osgood
    Osgood Western Thunderer
    That Bury type (?) locomotive looks intriguing.
  3. geoff_nicholls
    It's one of David Viewing's 3D designs blown up to G3. There's more explanation in my Geoffs G3 Workbench thread in the G3 forum
  4. Osgood
    Thanks - I've just applied to join the forum to view more.
  5. lankytank
    lankytank Western Thunderer
    Geoff, is it planned to 'try' and link it to Rundle or are you just trying to get them both in the same room?
  6. Mike W
    Mike W Western Thunderer
    Blimey Geoff. You build complete layouts at the rate I build single wagons!
  7. geoff_nicholls
    I did try to work out a way to connect the two layouts, but gave up. The original circular version of Rundle will just fit nicely in the same room, but not the extended exhibition version.
    I'm hoping this one will work better and last longer than the previous ones, it's smaller and easier to transport. Hopefully any changes will be limited to scenic stuff and stock.
  8. geoff_nicholls
    Some figures for the 1851 version of the layout have just been delivered from Modelu. They are very nice. Also at £25 each (this is gauge 3) very expensive. but compared to them Preiser figure look like caricatures. They are also very delicate, I managed to damage the brim of the GWR Policeman's top hat. The brackets on the building downpipe are also Modelu, the loco is David Viewing/Shapeways.
    Devonbelle, unklian, Alan and 15 others like this.
  9. john lewsey
    john lewsey Western Thunderer
    They do look good don't they
  10. Jon Nazareth
    Jon Nazareth Western Thunderer
    Yes, they DO look good. It's a pity that Modelu don't supply a Victorian loco crew.
    Jon
  11. john lewsey
    I believe that they are going to
  12. geoff_nicholls
    as John Lewsey says, they are planning to. I have contacted the L & M expert, author, and loco driver Anthon Dawson suggesting he get himself printed in his uniform. He would be idea for Enigms/Lion
    john lewsey likes this.
  13. Jon Nazareth
    Geoff
    Thanks for that and fingers crossed.
    Jon
  14. geoff_nicholls
    Work is progressing well fitting the Bury locos' tenders with motor blocks, but I was a bit concerned about the low buffer height, the equivalent of 2' 9". That is what it was when the drawings used by David Viewing were published in 1838. Most of my early stock has a buffer height about 3' 2". So I fitted wheels on the L & B break van built by Wright (also a David Viewing print). There is a difference, but it shouldn't cause a problem when running, and I suppose it is prototypical.
    The loco is the second of the two Bury locos, an 0-4-0 'Luggage' engine. I was very worried about getting quartering right, but one wheel is slightly loose on the axle, I should be able set it up and spin the wheels to check for binding before the glue sets hard.
  15. geoff_nicholls
    Quite pleased with this shot. L & B Bury 0-4-0, and ECR Parliamentary carriage.
    midnightmiller, Neil, SLNCR57 and 5 others like this.
  16. Mike W
    What are the wheels on the tender and van Geoff? Maybe its the picture but the rims look more delicate than Slaters. Are they maybe SpurII?
  17. geoff_nicholls
    They're Slaters, but I got Walsall to turn them down by as much as they could. Probably only 1mm, but noticeable. I'm working on an idea for a much narrower wheel 5.5mm thick.
  18. john lewsey
    Great photo
  19. Jon Nazareth
    Geoff
    Is the Parliamentary carriage one of David Viewing's prints? Either way, I'm jealous.
    Jon
  20. geoff_nicholls
    I scratch built it in ply laser cut from my own artwork from drawings in the GERS Journal. It appears if my Rundle thread.
