A small G3 loco
Discussion in 'G3' started by jamiepage, 9 April 2015.
  1. JimG
    JimG Western Thunderer
    Simon,
    I do remember that I was influenced at the time by a G1MRA member who I used to meet at get-t0-gethers in the Somerset area (Maurice ????? ) who modelled two rail electric and to finer track standards. I don't think Proto:32 (or whatever it is called :) ) had appeared by that time. The wheel castings were from Locosteam (now long gone) and I spent long, dirty hours filing the spokes down to be much finer than they were originally.
    Jim.
  2. jamiepage
    jamiepage Western Thunderer
    The Slimline Slomo has arrived from Australia. It has been designed to suspend sedan chair like, with the paired legs sliding into one frame cross member and the single leg into another. The single leg is threaded and fitted with lock nuts to allow adjustable chain tension.
    Overall width at 38.5mm is good for G3, and will allow it to disappear within a cosmetic firebox on this loco, but would still be too wide for G1.
    It is a very nice piece of work.
    unklian, chrisb, Steve Cook and 4 others like this.
  3. Steph Dale
    Steph Dale Western Thunderer
    Jamie,
    I have been waiting until now, so I can see what you're referring to, but what is it? Friction brake? Damper? Some form of flywheel energy store?
    I realise I now sound like my mother when presented with one of my 'unfortunate' pieces of junior school art projects; "Oh, that's very nice dear; what is it?"
  4. jamiepage
    Steph,
    Thanks for the chuckle. Yes, it's a load of gears and a gert big flywheel to flatter the slow speed running somewhat. I don't know how to do it myself, but Steve Cook kindly posted a link to the manufacturer near the start of this thread.
    Jamie
  5. Steve Cook
    Steve Cook Flying Squad
    Looks like it will do the job nicely Jamie :)
    Post 3 if you haven't found it yet Steph.
    Steve
  6. Simon
    Simon Flying Squad
    I went one better than that;
    "Oh that's really lovely, well done - can we put it in the bin now?"
    Scarred for life:))
  7. jamiepage
    Some reasonable progress over the last fortnight, mostly building a kit of parts in anticipation of some assembly soon.
    Still in two minds about the valve gear, but I decided to use the pantograph to mill out the various bits for Stephensons, so I'll try them first. . (Sorry, didn't realise how out of focus the photo was).
    Cylinder assembly is progressing quite well. In the end, DJB auto draincocks were fitted inboard of the frames, serviced by yet more long passageways from the bores. Cosmetic draincocks will be fitted under the bores.
    Cosmetic front endplates, with scale studs, screw onto the structural covers and the overall effect when combined with wrappers looks ok. The central steamchest has been drilled for various M2.5 bolts, the two central holes however are part of the exhaust passageways. Valve rod glands still require drilling, reaming and tapping through the steamchest's rear face.
    Smokebox components are ready for silver soldering. The front plate was again pantographed, complete with central hole. It was then wrung onto an aluminium mandrel and the door recess bored out.
    If, and it is quite a big if, the smokebox silver soldering goes well enough, the frames, smokebox, cylinders, wheelsets, coupling rods and Slomo can all be assembled, at which point it will hopefully feel as though progress has been made.
    mswjr, Bob Reid, unklian and 10 others like this.
  8. jamiepage
    Have just enjoyed an assembly of some of the chassis bits so far, mostly to check quartering and to fit the streamchest but also to sort out the Stephenson's gear and clearance around the Slomo.
    The chance to take a photo or two was too good to miss.
    Cosmetic cylinder end caps show up quite well here.
    Coupling rods fitted, albeit with temporary knuckle pins.
    Final photo just to have a look at the face with smokebox front pushed roughly into place.
    mswjr, ScottW, unklian and 12 others like this.
  9. jamiepage
    Very slow progress at the moment due to other stuff, but the eccentrics have been temporarily fitted along with the Slomo's final gear to check clearances.
    The Slomo itself will sit in the foreground space, within a cosmetic firebox/ ashpan.
    Roundhouse boiler, gas delivery system etc have been purchased and should speed things up once the chassis is running on air. The gas tank, lubricator etc will sit fairly well within the cab and R/C gear and batteries are destined for the tanks.
    The commercial boiler would fit well, but its boiler bushes are not quite right to prototype so I will make up a new boiler, identical other than the bush locations.
    It is a simple single flue boiler so hopefully shouldn't hold things up too much.
    ScottW, unklian, Simon and 9 others like this.
  10. Scale7JB
    Scale7JB Western Thunderer
    This is all looking magnificent, and plenty of food for thought for modelling in my next life... ;)
    JB.
  11. jamiepage
    Thank you, JB. It is good fun.
    The first thing to address when I get back to it will be the lifting arms/ suspension links. Currently they are planned to be 'inboard' with the expansion links suspended on their inside.
    However, the boiler sits low and it looks as though there may not be enough room for the links to 'lift' the gear fully into reverse in that position.
    If it is the problem it appears, separating them and moving them outboard of the eccentrics, just inside each mainframe, will provide a lot more headroom as the boiler curves up and away. That will mean a bit of a rethink to the pins etc to make sure it can all be assembled/ taken apart when needed.
  12. unklian
    unklian Western Thunderer
    Out of interest where did you get the design/layout of your valvegear from Jamie ?
  13. jamiepage
    Ian,
    Martin Evans' G1 'Southern Belle' Brighton Atlantic.
    Although the lifting links are different- well, at the moment anyway. The steamchest is also of course completely different (based more on Paul Forsyth's 'Director') but the ports are similar.
    In other words, nothing original, just poaching bits from here and there.
    Jamie
  14. unklian
    Thank you for that Jamie, I will have to look that one out. Its interesting how the detail of large G1 designs can be fiddled to suit small G3 locos.
  15. jamiepage
    Ian,
    I do agree. The G3 4-4-4T is to all intents and purposes a Paul Forsyth G1 design with different platework- cylinders, slip eccentric valve gear, meths tank/ burners, boiler etc. are all to his published designs.It wouldn't work so well for the larger prototypes of course, but works well for the small Edwardian types.
  16. Mike W
    Mike W Western Thunderer
    And medium sized engines can draw on Gauge 1 designs, if not actual parts. Barrett Engineering used their Gauge 1 experience and design to make Gauge 3 cylinders for my LNWR 18in Goods. Benefits included a tried and tested design made by a renowned builder, before one has even been steamed.
  17. jamiepage
    A record of some little progress.
    Cosmetic front cylinder covers had already been made, these simply screwing onto a central boss and so effectively camouflaging the covers proper.
    Cosmetic rear covers were more problematic. The gland, slidebar mountings etc precluded a similar arrangement, and the cosmetic covers also required a couple of steps incorporated.
    Silver soldered fabrications were made up, incorporating the steps and some bolt head detail (or rather, bolts will be fitted) and which fit
    over the rectangular central boss. The fit is a light push fit, but the slidebars should hold all in place whilst still allowing dismantling if subsequently required.
  18. jamiepage
  19. unklian
    Hello Jamie, a small question about your Slo Mo unit, do you have any idea what the overall gear ratio is ?
    Thank you Ian
  20. jamiepage
    Ian,
    Sorry, but I don't. Nor do I have enough knowledge to make an educated guess, I'm afraid.
    Jamie
