A spot of G3
Mike W
Thanks for the advert Steve!
Richard, if you want to know more send me a PM and I'll call you for a chat. There are other suppliers in Gauge 3 and several manufacturers are dipping a toe in the water, so I'd be very happy to chat about my experiences and give a (fairly) unbiased view.
This Troublesome Truck kept the original underframe which has steel solebars and a curious 9ft 3in wheelbase. Another way is to fit a complete new underframe. Scratch building solebars and headstocks is not hard, but the bits are available for wooden solebars and 9ft wheelbase if you prefer.
All the bits obviously add to the cost, but its still not an expensive model. For another comparison of costs, check out Slaters' website and compare their G3 wheels to G1. They don't list G3 at all on the website, but download the price list and its all in there.
AndyB
Here's a Troublesome Truck with a complete underframe replacement in progress.
Solebars and headstock are just laminated plasticard.
Axleguards are from Williams Models (Midland pattern but they suit RCH well). Ellis pattern axleboxes will be from the same source along with buffers and couplings.
Crown plates are my etches, washer and coupling plates cut on the pantograph mill - all with etched nut detail added.
Wheels will be the original Bachmann, on new 4mm steel axles
Andy
JimG
Just a question about G3 track. Is there any two rail electric operation? If so, are steam locos with non-insulated wheels allowed on - with two rail power off. :) Or do electric powered locos use batteries and radio control with no two-rail track provided?
Jim.
AndyB
Jim.
Jim,
Two rail electric is in use by a few, but I think that the majority of electric users are going for battery power and r/c these days. I stand to be corrected on the following by my G3 colleagues.....
I know of one semi-outdoor end-to-end which is 2-rail, then of the 4 G3 layouts on the exhibition circuit two are 2-rail and 2 are battery with r/c. I'm not sure the owners of any of these would welcome steam operation as they are all 'scenic', as per 4mm, 7mm, etc layouts - not resistant to condensate and steam oil!
Steam locos are generally run on roundy-roundy type tracks (outdoors), and I'm not aware of any of these being 2-rail electrified at all. So live steam and battery power happily coexist on these lines.
Hope that answers your questions.
Andy
Mike W
As Andy says, there is 2-rail in G3 Jim, but not much. With so much more space available and batteries becoming smaller all the time that is what the majority of people use, especially outdoors where voltage drop and that sort of thing can be a problem for 2-rail. There is a large end to end exhibition layout which has hosted one of its helpers' live steam GWR moguls from time to time, even though, as Andy says, live steam is currently mainly used on continuous circuits. I can't think of any other 2-rail lines.
Most battery powered locos I have seen will run for several hours without recharge, which is more than most people want, so there's not much advantage in 2-rail for us. In fact, as a convert from smaller scales I am amazed at my own changing views. I would not have believed that battery power could be preferable to 2-rail, or that brass rail may, in some situations, look better than "silver-coloured" rail, but in the larger scales both can be true!
JimG
Andy,
Thanks for that. On a battery/radio control loco with all metal wheels, is the practice to insulate the wheels or axles so that it can run on any track, or leave the wheels uninsulated and avoid two rail layouts.
Jim.
AndyB
Jim,
Again, I don't think there is a single answer.
The cast wheels on my 1F kit (from GRS) are insulated, and I believe Mark Wood will provide insulated wheels on request. But largely it is down to the owner / builder to decide, based on where he/she thinks they are most likely to run. For the running options that I'm most likely to use, I wouldn't bother with insulation.
With all these questions, anyone might think you were being tempted to dip a toe in the G3 water .......!;)
Andy
geoff_nicholls
Mark Wood supplied the wheels you see on my avatar fully insulated, as I'd originally planned to keep my layout 2 rail powered. However as soon as I had the first loco powered by RC and batteries, I stopped bothering with 2 rail. The only downside is having to make sure there are charged batteries in the controller as well as the loco. AA batteries seem to drain quite quickly.
Mark will also do insulation on one side only, if you wish.
Steve Cook
The weather held out yesterday and the first big get together of the G3 calendar took place :) Its a good sized circuit this one with three continuous running lines plus various sidings, loops and engine storage area.
Despite the generosity of space, G3 engines consume it at a rapid rate
In the middle of the circuit was a small gazebo with a table for items for sale and old engines, or more precisely, bits of old engines. With an average age of about 100, you can't fail to be impressed by the engineering and casting skills present then.
My favourite was Abergavenny
There was plenty of tea and cake on offer too, a perfect accompaniment to watching a variety of engines make their way around
G3 Dee, scaled up from the G1 book but fired on gas.
A half inch scale Super D fired by coal
A coal fired Patriot
A Royal Scot, Royal Legion, based on the frames on 'Fury' (clearing condensate before going out for a run)
A 2800, just bought but never run
A lovely little coal fired Manning Wardle built by Roger Marsh. It didn't run yesterday unfortunately, but it should get some fire in its belly next weekend.
A gas fired Mogul with owner built coaches
An excellent day out overall, I met a load of new people and spent all day talking and watching trains. Unintentionally, I missed out on the electric engines, examples of O2's, Terriers and Panniers all ran round the inner loop all day, I'll do better next time...
Steve
Steve Cook
Any more pics of the slightly hidden shunter ?.
This is the best I can do for you Steve - given it is an oddly proportioned 08 in a sea of interesting stuff I'm afraid it garnered very little of my attention span.
That Brighton J tank looks lovely, I'd happily give it house room!
£1500 was the asking price and its one of only two that are known about so far. I'll happily pass your details on to the owner if you like Steph :)
Its missing a handpump and a pressure gauge from a cursory inspection, I've no doubt you could get it working though - be both a great project and a shelf resident.
Steve
Steve Cook
Another weekend, another G3 get together :)
A smaller garden this time round, but none the worse for it by any means. The diameter of the outer circuit was around 29' with a running length in the region of 130'. Its been up for about 15 years and has blended nicely into the garden now (or the garden has blended into the railway depending on your point of view). All the track is built the old school way from individual chairs nailed into sleepers.
Looking back the other way
It followed a very similar set up to last week with a table in the middle for showing things off
Derwent is a SME Bronze medal winner
and so is all of the stock it pulls behind it. The builder is not scared of giving it a boiler full of steam either, it runs very well indeed.
The same owner brought his Dee along again
and gave me running lessons on it with his Pullman coaches running behind.
There was a second rake of Pullmans too, 12 wheel this time and running behind a scratch built Battle of Britain
A Jubilee waits for her turn
And gets to run in the rain as a result
To complete the usual fuel types, the layout owner fired up his meths loco
and she sauntered gracefully around the line towing a pair of coaches
It was another good day out - an endless supply of tea with helpings of cake in the afternoon to round things off nicely. Just two more weeks to the next one :)
Steve
Neil
I like the light and shade in the final photo, but my favourite loco has to be the careworn example on the table. It looks a bit SECR round the spashers, but beyond that I've no idea what it is.
A curious example certainly - again I've no idea what it is. With the cylinder location and driving the rear axle it has shades of a Crampton/French loco but beyond that I don't know. It may well be a freelance design - perhaps destined for a fictional location?
