If I remember rightly there are 2 parts 26 & 27 that you solder across the bottom. If you want to make them removable you will need to drill holes and fit tiny nuts and bolts. I hope that answers your question.Hello People
Been a while since I posted anything on here, got a chap to do a build for me of D J Parkin 35.5 ton tank wagon kit although now he has fallen rather ill and can not carry it on so I have managed to retrieve the kit which is about 85% finished and will try to find where he had got to in the instructions to hopefully finish it now I have a bit more building experience under my belt.
I am looking to hopefully spring fit the axle boxes with slaters hornblock springs with a bit of careful filling of the lugs on the underside of the leaf springs but have not come up with a method yet of stopping the axle boxes falling out from the bottom of the horn guilds when I pick the model of the track any ideas please?.
Hi Mark JIf I remember rightly there are 2 parts 26 & 27 that you solder across the bottom. If you want to make them removable you will need to drill holes and fit tiny nuts and bolts. I hope that answers your question.
Mark J
Hi Mark J
It does answer my question thank you although what size BA nuts and bolts would you suggest I could use? I was thinking 14 or 16 if they go that small.
Kind regards,
Paul.
I would go either 16ba or a metric bolt of 0.8mm.Hi Mark J
Kind regards,
Paul.
Hi Adam16BA is properly tiny - 14BA is 4mm loco crankpin size (about 1mm diameter) and easy enough to handle, in the scheme of things.
Hi Mark JI would go either 16ba or a metric bolt of 0.8mm.
1mm AF on a nut equates to almost 2 inch AF on the real thing. As tiny as it is I think it would be more to scale size.
Hello,Hello People
