CME & Bottlewasher
Guest
Hi All,
I am trying to plan for supplying DCC to the garden section of Down Ampney - although RC is not out of the picture yet and I may operate a hybrid of the two systems.
I hope to fit a BUS rated up to 10 amp.
I was to use some ex-T&E copper - single strand - for the droppers (from the rail to the BUS) and I have been recently told that such may be too brittle in the long run (in terms of 'movement' in outdoor conditions etc)......I know that we have discussed similar before, yet 'current wisdom' seems to have moved on .
It has been suggested that I use either 7/0.2 or 16/0.2 cable (which is 'Equipment Cable') the only issue I have is that I cannot fathom what the amperage is for these stranded cables and I have come across 3 amp, 5 amp and 1.5 amp being mentioned
The BUS will cope with 10 amp and to start with the Booster/Command Station is 5amp and
as such the dropper wires will only have to cope with passing amps, yet I am well and truly confused now
Thanks in anticipation.
CME
CME
