My son is detailing the resin roof and underframe, plus the etch walls of the compartments, of a JLTRT coach body with styrene sheet (actually, Evergreen strip or Plastikard sheet from Slaters). Early attempts used Deluxe Rocket Rapid and there have been some failures where the styrene has come away from the resin. Similarly, some joins between styrene and brass etch are failing with the styrene peeling away when the brass "moves or flexes" while handling the body. Just in case you thought... all of the parts have been washed in pure soap solution - no lanolin - to remove any release agent or etch residues.
I have thought of using epoxy adhesive applied to the styrene after sanding the styrene bonding surface to give some grip. An alternative could be to attach styrene sections to the resin with superglue and then to insert brass pins through the styrene and into the resin... clearly this is not going to work when styrene has to be attached to brass etch.
What method of fixing styrene to resin and to etch brass is going to be secure in the long term and, specifically, during assembly of the model where handling tends to induce movement of the body components?
thank you and regards, Graham
