LarryG
The other day, my good friend Adrian R., better known as Northstar Design, gave me a Dapol O gauge BR goods brake van that he had comprehensively backdated into an early LNER Toad D. 99% of the conversion had been done and it was simply left to me to 'floor' the verandas and tidy up. An as-bought BR brake van straight out of the box....
Note shorter stepboards on LNER Toad D below....
The earlier LNER vans had no concrete or cast iron weights and no trussing below the solebars so they were removed from the model....
The 'sideframes' had been held vertical by the platform weights and so Loctite was run into the grooves as shown in green (both sides).....
The earlier vans had windowless matchboard doors. Adrian made these from Plastikard...
He also fitted brass lamp brackets. I finished the model off with 16thou thick brass veranda floors. They will be painted prior securing to the model. Of note are the replacement grab rails that differ from one-piece handles on the BR brakes.....
