Spitfire's G3 Workbench
Discussion in 'G3' started by Spitfire2865, 8 December 2017.
  1. Spitfire2865
    Spitfire2865 Western Thunderer
    Thanks
    So I start with a grey primer and then an even coat of a light tan. Then start drybrushing every woody colour you have. A bit of silver drybrushed every so often in certain areas. You should end up with a varied colour across every plank.
    Then start picking out certain planks with slightly heavier or lighter drybrushing.
    Overall a heavy wash of black wiped across the planks to sit in the gaps.
    Then another black wash lightly wiped along the planks once the previous is dry. I think I ended up doing 3 or 4 washes by the end.
    Then brush with dark powders to take the sheen off. Ive done powders on both wet and dry surfaces before, so you can try a bit of both and see how that ends up.
    If you wanted a replacement plank, youd then have to repaint those the lighter colour with a lighter drybrushing.
    Its a long process but Ive used similar in both 4mm and G3.
    Dog Star, DavidinAus and Ian_T like this.
  2. DavidinAus
    DavidinAus Western Thunderer
    It does sound a lot of work, but easily worth it. Thanks.
    Fortunately the HiChem All-Surface Primer is grey and very thin, to start with.
    I will give it a try.
    David
  3. Spitfire2865
    While I regain my strength to retackle the Midland open, Ive begun on a 16Mills kit.
    Specifically the LBSC 4t ballast.
    Chassis put together and a side being worked on. Im going to use rivets with fake nuts to represent carriage bolts.
    Just have to source fake nuts now....anyone got a source?
    Ive also got a couple side tippers and WC minerals from Dave to build as well but those will have to wait for more wheels.
    Just from what Ive done so far, these kits are excellent with plenty of easy detailing to be done.
    Peter Cross, Arty, Dog Star and 2 others like this.
  4. Spitfire2865
    Well, progress.
    I must say, Im really impressed by the lasercut card strapping. Soaked in CA, it makes a very nice material that sands easily and holds its form well. Corners round off really nicely too. Sand enough and the seams just disappear.
    Coach bolts represented by rivets with drilled out 14ba nuts soldered on.
    Ive also had my first try of the CA and baking powder filler technique. Very effective for filling some unneeded lines around the buffers.
    Once the strapping is finished, Ill get onto priming and painting my usual wood effect.
    john lewsey, AJC, Dog Star and 5 others like this.
  5. Jon Nazareth
    Jon Nazareth Western Thunderer
    Trevor
    What is a 'WC mineral' and 'CA'?
    Jon
  6. Spitfire2865
    West Cornwall mineral wagon (as offered by David Mills of SixteenMills) and cyanoacrylate (I used the thin stuff to stiffen up the card)
    Ive got two of the former to build as well as his side tippers to make a bit of a freelance contractors train behind my neilson.
  7. Spitfire2865
    Well Ive got a couple side tippers mostly assembled.
    I have quite a few NBW castings coming in the mail soon so plenty of detailing to add to all 5 wagons.
    john lewsey, Arty, Dog Star and 3 others like this.
  8. Spitfire2865
    Well I had a 'fun' afternoon.
    I had a slight disagreement with a pothole while driving home. This resulted in a voilent blowout of the front and a flat on the rear. 20190410_172144.jpg
    The rest of the afternoon and evening sitting by the roadside, in a tow truck, and in an autoshop has seen me with 4 new tires, an oil change, and significantly lightened pockets.
    Im ready for bed....
  9. oldravendale
    oldravendale Western Thunderer
    Did you manage to get a photo of the pothole, and precise location?
    I believe that local councils are liable but require evidence. I had the same issue on one of the Buckinghamshire country roads and the District Council advised that tis was necessary to accompany a claim. When I went back the pothole had, of course, been filled. The Council has some wriggle room, though. I believe that the hole has to be unreported, or if previously reported marked up and dealt with within a certain time - three days i think. Those conditions may not, of course, be standard across the country.
    In any event that's really bad news, Trevor, and I empathise.
    Brian
    simond likes this.
  10. Spitfire2865
    Well I expect my local government here in the US to prove even more useless.
  11. Spitfire2865
    Eating 3 (well really 9 but who's counting?) elephants at the same time. But some progress on each.
    The two side tippers are mostly assembled and working on details. Strapping done on one, nut castings done on both. Plus the chassis have had some black sloshed on em. Black seemed a fairly reasonable colour for something like this. Dumb buffers added to the headstocks and Ive filled the bufferstock mounting holes with Apoxie sculpt. A beautiful material for those uninitiated. 2 part epoxy putty that can be worked so easily both wet and dry. Even is machinable and can be tapped!
    The sole ballast wagon finally got a coat of primer today before my typical wood treatment. However I have just realized I forgot to add the nameplate. Suppose it wont be much issue adding it later.
    And a start on the WC mineral wagons.
    One I think Ill build normally.
    Thought itd make an interesting variation, regardless of its usefulness on such a low sided wagon.
    You can also see the modifications needed to fit the coupling hooks I have.
    Jon Nazareth, Arty, JimG and 3 others like this.
  12. Arty
    Arty Western Thunderer
    Excellent work Trevor, one of the reasons I like David’s kits is that they can be modified so easily.
    Spitfire2865 likes this.
  13. Spitfire2865
    Im not dead.
    Just havent been working on trains.
    But I do have the etched strapping for 3 more D299s. Just in time to be replaced by the Slaters kit.
    Jon Nazareth, Rob Pulham and Arty like this.
  14. Arty
    They look very nice Trevor, did you get them etched “locally” ?
  15. Jon Nazareth
    Trevor
    Where did you get the nut castings from?
    Jon
    JimG likes this.
  16. Spitfire2865
    All my etches are from PPD LTD. Theyre quick and helpful, so I cant complain. Ill be building the D299s eventually, but theyre a LOT of work on account of the 4 doors and multiple catches so it may be a bit. Still on a binge of other work so we will see.
    Those are from IronCreekShops.com here in the States.
    F scale but close enough. Hes got a few "normal" nbw patterns and he will run a mold for you very quickly. Took him a day to do my order of bits. He also offers a WM casting service IIRC.
    Arty, Rob Pulham and Sleeper Agent like this.
  17. Jon Nazareth
    Trevor
    Are they brass or plastic nuts? I should have asked the first time around.
    Jon
  18. Spitfire2865
    Oh, neither. Ironcreek does whitemetal casting only.
  19. Spitfire2865
    Wow. Its been a while...
    Have had a massive binge of wargaming, other modelling, helping a friend learn to make things, and generally being a lazy bastard.
    But Id like to do SOMETHING with trains.
    So I figured Id start with finishing off a couple sixteenmills kits Ive had in a box for the past half a year.
    Still need to repaint the strapping and internal woodwork.
    Higher ended wagon waiting for strapping and NBWs.
    And I tried to drill out some LBSC brass axleboxes and well...
    I dont know why I expected anything else from myself.
    john lewsey, AJC, mswjr and 3 others like this.
  20. Jon Nazareth
    Trevor
    I usually use the mill to open up axle boxes, by raising the table, there is no risk of snatch.
    I looked back at your Nielson coupling rods and they've come out really well. I wished the ones that I made for Lion came out as well. Even though the rod part is round, I expect that something could have been dreamed up for the ends by using etches.
    Jon
