Steve Cook
I guess this isn't the usual way to start a project thread, describing the destruction of a perfectly good layout, but sometimes you have to go backwards to go forwards. As mentioned in the tail end of the Boomers Wood thread, the layout in question is / was Stroudley Green, built by Maurice Hopper. It had passed through the hands of Simon D (gaining a set of legs in the process) before arriving home with me ready to spend a couple of years in the loft
Having gone through a rationalisation of my modelling projects, the layout has made it downstairs for evaluation of what to do with it. Originally I had intended to model Totland Bay (the proposed terminus of the Feshwater Yarmouth and Newport Railway) and figured with the layout being based on Bembridge that this was a possible scenario. It never really lit my fire though, so a change of plan saw most of the related stock sold and I'm back to trying something that feels more manageable within the time I have available.
As a starting point I have a G15 tram kit, a selection of open wagon kits and a single box van kit, plus a few wheel sets, underframes etc etc - enough to get me going and to provide a starting point (I'm rather partial to the trams, moreso having run one of the Quayside of Trevor Nunn's East Lynn layout). If there is a downside, is thats the G15 rather limits the choice of prototype location, on the other hand, that makes it slightly easier to choose one
Having mused over the options, the Wisbech and Upwell Tramway came out as favourite, there is plenty of material available for research and it is an enticing prototype. Having confirmed with Maurice that he would have no objections to the layout being considerably revised, I've settled (for the time being at least) on modelling the proposed extention of the tramway up to Wisbech Market Place. There are a few things going in its favour, it can be freelanced to a degree whilst still remaining true to the original tramway, its doesn't have a huge variety of stock, most stuff is short wheelbase so unlikely to upset the proportions of the whole layout and the physical constraints of the Market Place can be used to justify the track layout. There are quite a few photographs of Wisbech Market Place on the net, covering stuff from 1900 through to current, with some cracking buildings to boot.
The first thing to do with a location in mind was to strip the layout down to boards, track, wiring and point actuation - at least it is still a working layout in this form, if not quite as nice to look at.
The starting point
Close up of the turntable board
The tools of the trade, chisel, sharpened screwdriver, glass fibre brush and a solution of 50% water, 50% IPA. By the time I'd got round to doing the crossing and the points I'd added a couple more small screwdrivers to the list, and I mustn't forget the hoover for cleaning up afterwards
All of the main scenic covering was removed in as larger chunks as possible to minimise the mess, the station building has survived but for no real reason, it just seemed a shame to destroy it. With the boards clear, the water/IPA solution was dribbled onto a 12" section of ballast and left to soak in for five minutes. Another application over the top, then gently scrape off. Sounds easy, it most definitely wasn't. Some of the ballast is so well stuck down its still on there, I'm sure I'll damage something if I keep going. Fortunately, it only affects the run in from the fiddle yard and the first point and it is all now beneath sleeper level.
A bit brutal it could be said, but I like the fact that it is now almost a blank canvas. I've a large set of decisions to make now - good timing as there is little opportunity over the next few weeks to get any physical construction done, but up for consideration are
Exhibition friendly or just moveable?
Operate from front, rear or both?
DC or DCC?
Manual point actuation or motorise?
Removable baseboard extensions ala Boomers Wood?
Add to current trackwork?
Backscene?
Presentation?
Lighting?
Height?
Stock list?
etc, etc.
Currently, the image in my mind is representing the top of the Market Place with a road, then buildings behind the rear most track. I'd like to add an extra point leading off to the rear from the main line of the loop, running across the road and into a loading dock set slightly back and at an angle from what would be the main street.
Buildings on the left and right hand sides to frame the scene, with the cutaway section of the board reinstated at the front to provide a place to put the market stalls etc. DCC, and push to change motorised points are the current favourite as that allows operation from both sides (easy enough to have two separate control panels with push buttons for actuation), but I've never had a lever frame before and I think I'd like one. However, the previous layout showed that project creep is an ever present concern, so nothing is yet decided and I reserve the right to change my mind (daily if required!)
Steve
The starting point
DC or DCC?
Backscene?
Presentation?
Lighting?
Height?
Stock list?
etc, etc.
Steve
