Some of it will have to be scratch built. Specifically the LNWR 2-4-2T and 0-6-2T, fortunately no outside valve gear and the wheels are available from the 2mm stores. That's one thing I've noticed quickly with 2mmFS it's dead easy to scale dimension (compared to 7mm anyway!) whatever the dimensions are in feet then double it and that's your answer in mm. So for the coal tank drivers are 4' 5 1/2", near enough 4.5 ft, double it to get 9mm - look at the stores list 9mm h-spoke drivers - that'll do for me.Will you have to scratchbuild the motive power?
There is a replacement chassis kit for the Ivatt 2-6-2T from Dapol. However I don't know whether my reputation can stand it but just to get things moving I bought a Farish Class 24. Might be a bit too far to post a photo but it's as close to RTR as you can get on 2mmFS, 5 minutes to drop in a set of wheels from the 2mmFS association, at least it'll have a PMV to lug around now.
