Jim,
Re MP15DC glazing, your right, it's designed not to come out! There's four small black clips that hold the front and rear pieces in, pop those out and then I worked on the front piece and just pushed until it broke in the middle, you could score it with a craft knife on the inside first to 'persuade' it to break cleanly. Once the front is out then the sides come out by pushing the front quarter lights in and working the rest free, once they are out then the rear comes out but was still quite difficult until I took the rear light cluster out.
I'd already decided that I was going to flush glaze anyway so it didn't matter if it broke, I didn't like the look of all that glazing support inside and glass that's better suited to an armoured car. Plus, on the BNSF model they have painted some over in orange to represent the filled in ones and the paint wasn't going to come off them at all.
I'm also going to level the cab floor, add a false ceiling with a couple of surface mount LEDs behind and in the chassis, drill two small holes and try to replicate the rear bogie inspection lamps. Levelling the floor will mean a new control stand (or new base) but that's no hardship and inside the two rear lower windows I need to add the kick bar.
That's the plan anyway, haven't touched it for a while as I really must get these W1 frame etches sorted, hopefully off to PPD later this week, then I can get back to the MP15DC
Hope that helps.
Mick
Hope that helps.
Mick
Might also be able to lift those drawings as well into AutoCAD as I think it might be possible to work up an etch for the side frames with internal bracing. Etch can be a little crisp so you'd need to smooth off the edges to give it a bit of a cast feel.
(This means you Candy Armstrong TechCare Engineering Support head that didn't even return my call
). The final model is an amalgamation of information gleaned from the SCTCO manual, multiple Car and Locomotive Cyclopedias, the Norfolk and Western Historical Society, lots of photos, and some crawling around underneath a car at the Colorado Railroad Museum in Golden. I finally had to concede that it would not quite be perfect but very close. A concession that also entailed a case of the hives, twitching of the eyes, insomnia, and general apoplexy. The revised truck (shown only in the colored drawing) added a lot of the details like the brake rigging, wear plates, and side bearings, and addressed most of the existing errors as I found more information after the fact. There are maybe three things I would fix now. The reality however is that over the years there is such a tremendous variety of truck styles cast by any number of foundries under license, that I can't even say my version isn't right on. Of course there are several modifications I would pursue for the practical purposes of use in the model railroad environment.
). Or maybe we can collaborate somehow to get the thing printed, or cast, or injection molded, or die cast.
