Small BA Screws - supplier
Hi,
I needed some small BA screws for some of my current projects but Eileens always struck me as being quite expensive so I started flicking through the internet as you do. I stumbled upon this site
http://www.screw-shop.com
Apologies if already broadcast but I liked the prices - placed an order Tuesday lunchtime and they were delivered today (Thursday).
Gratuitous photo just to make it look colourful!!
They do a much wider range than Eileens, they go down to 16BA, brass, steel, stainless in a wide variety of lengths, the short ones in the photo are 14BA x 3/32 (£2.10 for 25).
Price comparison examples :
16BA x 1/2" brass ctrsunk pack 100 Screw-shop £10.56 - Eileens £20
12BA x 1/4" brass ctrsunk pack 100 Screw-shop £4.92 - Eileens £18
At these prices I think I'm going to stock up on a selection rather than just buying as required.
No connection with them - just a satisfied customer.
Hopeful useful info for people - unless someone can come up with a better supplier I missed?
Osgood
They seem good prices for small brass, I'll have a look.
For Steel, about the cheapest I can get plated high tensile setscrews is;
M4 x 12 £1.98/100, M4 x 12 £2.08/100.
Stainless are about double that.
The real bargain for DIYers though must be 1m lengths of threaded stainless studding - 3mm dia £0.98, 4mm £1.28!
alcazar
Guest
I would point anyone wanting fasteners at:
Items Mail Order Ltd.,
Mayfield,
Marsh Lane,
Saundby,
Nr Retford,
DN22 9ES.
Tel: 01427 848880
The chap that runs it is very knowledgeable and will send you a large printed list in A5 booklet form for an SAE.
Ordering is by phone or in writing, items usually with you next day, good prices, excellent range and good stock levels.
Some tools also stocked. He takes credit/debit cards.
Again...satisfied customer.
Yes - used them a few times for miniature rivets and dummy bolts. I've not tried the machined bolts as I prefer BA threads rather than metric, mainly due to the taps and dies I have in my toolbox!
I am searching for fasteners to help with assembling the inside motion for a 7mm Bulldog... and the Master of Ceremonies has requested 16BA hex head as first preference... none of the suppliers mentioned in this topic to date are able to help with my search and, after 20 pages of links, neither can Google.
Anyone wish to offer suggestions?
Graham,
It might be a good opportunity to go metric. M0.8 screws have 1.3mm af hex heads, if it's hex you need. They're reasonably easy to get hold of as they're a common size for spectacles.
Personally I'd use wire and rivets for valve gear: less chance of it all coming undone!
Jon Nazareth
I use 'Items Mail Order Ltd'. If you order in the morning it normally comes next day. No website or email but telephone number is 01427 848880.
Jon
I have used "Items" preferentially for several years and did call the guy yesterday - neither 16BA nor metric fastenings.
Rob Pulham
Maybe... just that I have 16BA taps and dies
Hi Graham,
If you have 16ba taps and dies could you not make your own by soldering 16ba hex nuts onto rod that you thread yourself? Being so small you probably won't be able to get enough torque to break the joint when tightening in normal use.
If you have 16ba dies could you not make your own by soldering 16ba hex nuts onto rod that you thread yourself? Being so small you probably won't be able to get enough torque to break the joint when tightening in normal use.
True Robin and that is one option which has been discussed with Paul (@Locomodels). Whilst Paul requested steel nuts and bolts I have not been able to find any 16BA fasteners in steel whereas 16BA nuts seem to be available from several sources. Time to look for some brass round bar from which to make short 16BA studs.
Stevesopwith
Leaving aside the metric v. imperial issue; I recently came across 'Prime Miniatures' whose range includes metric hex bolts...0.6 x 6 mm, head 1 mm AF, and 0.8 x 6 mm, head 1.3 mm, in brass or tinned brass. I understand 16 BA bolts have heads at 1.4 mm AF.
The 0.6 mm are £6.75 for 10, while the 0.8 mm are £5.00.
I'm using the 0.6 mm bolts, nuts and washers to represent the tie rod end detail on 7 mm GER wagons.
They are good, and he's very quick.
Ian@StEnochs
Have you got a contact address or website please?
