Brushes loco and wagon disaster workbench.
BrushType4
I hardly know the hot end of a soldering iron to the cold end and I really want to build the great brass locos and wagons that I see others doing here on Western Thunder.
So I recently purchased a J15 and after a protracted delivery it arrived today with some extra bits and bent bits.
9E5E8F73-5D28-4B2C-8B60-E38481B76C38.jpeg 2BCDD824-049A-4ABC-8699-DF6DAA55E846.jpeg
Unlikely to get any recourse from the seller I thought this could kick start me into learning some new skills and provide a bit of soldering iron practice.
First question, does anyone recognise the origin of the kit? It’s Brass with white metal parts.
2996572C-68B2-4428-A98C-89678C9908FB.jpeg EED833B6-523C-4E0A-B2AD-45B4F1B2E620.jpeg
Eastsidepilot
It may of been one of the old G.E. Models kit although I don't know for sure if they did the J15, certainly the D16 and E4....terrible kits by today's standards.
Phil, be aware of Gibson stuff, some of the castings are a bit under scale , the domes for one are very under nourished.
Col.
richard carr
IPA does work well and should be fine on slaters wheels. I have just dunked a class 46 body from a JLTRT kit in it and after about 10 minutes the paint started to come off easily, I did use 10 litres of IPA though.
Celly thinners will do the metal body but I would test it on the wheels though. 5 litres of celly is about £20 on amazon delivered. IPA is £30 for 5 litres.
Nitromors works fine on metal too but will probably eat the plastic of the wheels, it definitely eats resin.
I hardly know the hot end of a soldering iron to the cold end ......
Trust me, you'll soon work that out sharpish :))
Personally, I'd repair it, sell it on and use the funds to buy a new kit.
At a wild guess I'll reckon once you've striped the paint you may not like what you find underneath and there's a good bet some parts are glued on......expect more to drop off before you even start to refit what already has.
paulc
Hi Phil , body off the chassis and a dunk in thinners or acetone then brush the odd bits of paint that are still stuck with some more thinners . Check the bottom of the container for bits that were glued on as they wont be now , i use a foil roasting pan and wash it out after each use .
Just a tip , if you're not familiar with the loco take some photos . I done a repaint for a mate and stripped his loco the usual way ,i then had a dig around for the bits that had fallen off . One part took me the best part of a week to work out where it went let alone what it was but then it was a GWR Manor and i usually model LNWR
Cheers Paul .
