Timber cut plan
I think you have 2 options and to some extent it depends what you want to use for your backscene, photo print or artistic painting.So, best material to use for the curvy backscene? Looking for something that can go down to a radius of about 4" / 100mm.
Option 2 was getting a photo printed on a roller blind and using that as the backscene as used and demonstrated by Gordon Gravett on several of his layouts.
Hi Chris,
By moving the GS line to the front, would make vehicular access/egress to the yard very difficult and dangerous bearing in mind the slope of the road coming off of the bridge. In the first plan could have the yard access from the station forecourt area just to the right of the hedge or even anywhere straight off of the front edge below the GS. Just a thought.
regards
Chris,
if you put the two 184mm pieces to the gap in the upper right corner, you can shift the 550mm pieces to the left so that you get a clean cut at 1500mm.
Michael
Hi Chris,
regards
Chris,
Michael
