michael080
What I couldn't do was change addresses, seems not all write to module buttons actually write to the module So, I can now change an address.......yaaaah, but, it still will not let me read decoders at all. I still suspect it's a power issue as reading the Dash 8 makes a clicking noise, exactly the same noise when you first place the engine on the track, why it will let me edit the address and not read it is still a mystery.
I had the exact same problem and the solution was to use a larger power supply. Strangely, the originally used power supply was a powerful lab supply, but it still didn't work. I am using a notebook-style brick supply now and all problems disappeared. Reading from a DCC controller basically means that the motor current is switched in a high speed pattern. This requires a fast response from the power supply that many can't provide.
Michael
