Giles' misc. Work bench.
Podartist79
Hello Giles,
Another masterclass! Absolutely superb and inspiring work as ever.
Love the scale dents and dings on the back spectacle plate, will be interesting to see how you replicate that now on future models !
Best wishes,
Neil.
Giles
We now have 14 of the blessed things - and that's quite enough!
2021-07-12_05-02-16 by giles favell, on Flickr
I've also been sorting some coaches. They're converted Bachmann Tram cars (obviously!) With vents fitted in the clerestories and all the controllers etc removed. The roofs will be properly fitted after all four passengers have been installed.
2021-07-12_05-01-00 by giles favell, on Flickr
Giles
Thank you Gents.
At this stage I think it will be a motorised (slightly) inclined rising rod, which could possibly be attached to the hands/arms of an articulated person- but that is a little way down the line. The tip will be on the upstage side of the wagon as the ship is to the audience.
Rob R
Well, I've been looking at the issue.
Giles,
As you are using a gear motor is there any particular reason you didn't use a crank straight off the gearbox output to push his arms up?
Sort of one rev per wagon with a micro switch on the crank at arms down and a push button to start the whole process off?
Giles
Hi Rob,
A couple of reasons I suppose - a linear actuator gives me full adjustment of stroke, with the same mechanical advantage and speed in any position. I also really wanted to avoid flexing the wire and very much wanted to keep it straight. I did consider a cam, as I did for my point motors etc which also accommodate microswiches, but I wanted to try these flip motors with the threaded rod to see how good they were. I certainly want a pause at the top, so it looks less 'mechanical' (the point motors have this facility, but one would need a very big cam to get the travel!)
Podartist79
You hugely push the envelope and pioneer these things Giles - AMAZING!
It’s always a thrill and pleasure to see what you’re going to do next!
Neil.
Giles
A little something I've been looking at. A Bagnall that I've always found rather attractive, but I only ever found reference on the IRS website - and that was one drawing, and two very poor pictures. I stared looking at them (on CAD) and working things out, and realised that there were significant differences between the drawing and the loco as-built. It then came to light that there was a better drawing in a very good book together with two much clearer photos, and also the excellent Steve Bell had produced a drawing in 16mm. All these proved informative, and the result is this drawing, which I believe reflects the situation of the As built more clearly than previous iterations.
Bagnall Ashanti Diesel by giles favell, on Flickr
