Used to regularly see 47500 and her sister 47501 together at Willesden on weekend visits in 1964. When I get around to building my Connoisseur Jinty kit, it will be 47500 so a very useful photograph!Thanks for your thoughts on this, Mick and you may well be correct. However, I regularly found that locos which had been moved within sheds without their rods arrived with wheels out of sync and I'm ignoring the photos I took at Barry for obvious reasons.
Here's an example. 47500 continued to work for a further year so was not being stripped - in fact it went back to Bletchley and was withdrawn a year later. However the centre axle has been removed and the wheels are out of sync.
Further advice from anyone who has actually moved locos around without their rods will be a valuable addition to these thoughts.
Brian
Oddly enough, the undated IA Locoshed Book [LS/1305/97/300/864 on the back] but probably end of 1963 gives 46122 as being allocated to 16B Annesley.Well I suppose I' ve moved enough locos without rods on to comment, it makes no difference at all, they always end up misaligned and you have to skite the wheels around when putting the rods back on. The pic of Gwalior has misled you though Brian, that the crankpins on the remaining wheels are in alignment is happen stance, not an indication that it hasn't moved since the middle axle was removed.
Re 46122 allocations, this is the info I have,
Longsight 12/10/46
Trafford Park 25/4/59
Longsight 13/6/59
Bushbury 7/11/59
Willesden 3/12/60
Trafford Park 4/2/61
Saltley 17/6/61
Trafford Park 17/12/61
Upperby 30/6/62
Kingmoor 21/7/62
Wdwn w/e 17/10/64
No mention as one would suspect of Nine Elms even on loan and as Adam commented sufficiently unusual to have been well reported, however my info is still at odds with others.
Martin
Thanks Arun, but what's WHTS?
BrianFirst a quick thank you to everyone - and there were quite a few - who took time out at Guildex to let me know how much they value and enjoy this thread. I've been directed to some additional prime sources for information for which I'm most grateful. I can't promise to use them all for every photo - well, I could but then I'd be lucky to be able to show a single picture a day - but they allow for some further checks when information looks flaky.
Which leads me neatly on to thank Arun for putting me in touch with WHTS, about which I'd been previously unaware. Then further thanks to Adam for the link. Arun - you refer as an example to details for 6670, but in WHTS on line the info is rather briefer than you've suggested. Is that because the hard copies you have are more up to date or complete? I have, of course, looked in to the on line data for 48363 and I'm not finding any reference to Aintree as the last shed from which the loco was withdrawn. There's also some uncertainty about whether the loco was at Buttigiegs in Newport for disposal, even though recorded in the Railway Observer and a Railway Magazine report that it arrived there on 20th June 1968.
There's no doubt that these reports add more grist to the mill and make it easier to challenge and hopefully update other records and my inclination is to rely on info from the SLS, LCGB and Railway Observer/RCTS although doubtless there were a few charlatans within those organisations who were, let's say, less than reliable and open to uttering some terminological inexactitudes. It's my guess that they were probably found out quite quickly, though. I'll also assume that records from Kew, where they exist, can be regarded as a primary source.
For the time being I'll continue to rely on the SLS as a major source but WHTS will now be my primary source in confirming final shed and disposal details where they are missing.
I've run out of time to add photos to this post but hope that I'll be able to do so later.
Brian
In fact, since Mickoo kindly suggested that the sources of info should be named I've tried to do that in the knowledge that they are at best secondary sources. Those articles from Railway Magazine are an eye opener to be sure. Peter Hands must have been beside himself with frustration when he discovered there was an individual telling him fairy tales as fact. I suppose one could argue that he should have checked the source with the story teller but that's sometimes difficult.
