Well, I suspect that without a root, there’s no bocageApparently that’s an alternative spelling rather than a root.
Any chance you could elaborate on this, please? I'm planning on doing something similar, knowing what pitfalls there are would help!Here is my Drewry shunter (modified Airfix kit with Branchlines chassis) sorting wagons at Cwm Caradoc.
Unless its name is Ivor.....Nothing looks more ridiculous than a loco working with no crew
Hi Mark,Any chance you could elaborate on this, please? I'm planning on doing something similar, knowing what pitfalls there are would help!
What extra work did you do to the Airfix kit? I was thinking of using the High Level chassis so it'd be useful to know how well the Branchlines chassis goes together.
The Dean Goods looks very nice with her crew!
Thanks,
Mark
Hi Mike,Hi Mark,
Here are a couple of pics of the Drewry chassis. Although I built it a long time ago, I remember it went together very well. The motor is a Mashima 12X20, and I always fit a flywheel if possible. It can just be seen that the N/S chassis has overlays. I think these may have been the original plastic frames, which incorporated the sandboxes, and usefully widened the chassis for EM gauge. A compensating beam is between the 1st and 2nd axle.
All the moulded handrails on the body were removed and replaced with N/S wire. To be honest I can't remember if I added much detail to the original kit, I think it mainly consisted of wire for the sand pipes etc.
I have no knowledge of the high level chassis kit, but would imagine it's pretty much state of the art, although I have to say the Branchlines chassis runs superbly.
View attachment 223289View attachment 223290
Hi Mark,Hi Mike,
many, many thanks for the additional information!
The Branchlines chassis still looks like a very good option, and seemingly Branchlines still do a detailing set for the Airfix body. Thanks also for clarifying re the handrails, pipework etc.
One other thing, though. You mentioned using the plastic chassis as overlays for EM gauge - does the Branchlines chassis only cater for OO gauge?
Cheers,
Mark
Thanks again, Mike, that's brilliant. Branchlines seem a bit elusive these days, but I managed to get their pdf catalogues a couple of years ago so I'll try to get up to date versions!Hi Mark,
I think the Branchlines chassis is supplied with 00 spacers only from memory, but it was no problem using the plastic frames overlays, in fact, as the sandboxes are moulded on, it saves having to cut them off and and attaching them to etched frames.
I'm not sure if sandboxes are included in the detail kit.
regards
Mike, your old Drewry 04 is lovely. The Branchlines chassis includes spacers for 00,EM and P4. For Mark's info I include a shot showing what you get from the two suppliers. The High Level kit comes complete with gearbox, hornblocks, overlays and a few castings. There are lots of shots of models on the EMGauge70's site, along with a detailed build of the High Level chassis kit. The black chassis is a High Level not built by me, the other two rigid frames are Branchlines.Hi Mark,
regards
Hi Paul,Mike, your old Drewry 04 is lovely. The Branchlines chassis includes spacers for 00,EM and P4. For Mark's info I include a shot showing what you get from the two suppliers. The High Level kit comes complete with gearbox, hornblocks, overlays and a few castings. There are lots of shots of models on the EMGauge70's site, along with a detailed build of the High Level chassis kit. The black chassis is a High Level not built by me, the other two rigid frames are Branchlines.
Hi Mark. Cheers. The HL overlay is footplate chequer plate and jackshaft grill. I've read that the following email works : branchlines100@btinternet.comHi Paul,
many thanks for the info and comparison photo. The High Level chassis certainly seems the more comprehensive, and of course is much newer and hopefully up-to-date. Are the overlays you mention for the chassis or for body details? I have one of High Level's 14xx chassis kits to put together, which also looks very nice.
I've emailed Branchlines this morning for a set of current catalogues but it bounces back, so there seems to be a problem there.
Many thanks,
Mark
Great, Paul, thanks for the extra info. I'll try that email address, too! And yes, absolutely, Mike's model is a gem!Hi Mark. Cheers. The HL overlay is footplate chequer plate and jackshaft grill. I've read that the following email works : branchlines100@btinternet.com
Mike's model is superb - gives us something to aspire to.
Thanks, Mike, that's useful to know! I'll try the email address that Paul has given and, if that doesn't work, then the electric speaking telegraph (as Iain Rice would have said).Just realised the sandboxes in the plastic kit are separate and not moulded on the side frames, sorry!
Thanks to Paul for the photos which clarify things regards the Branchlines chassis, I built mine over thirty years ago!
I think maybe the best way to contact Branchlines is by good old fashioned telephone
Thanks for all your kind comments and likes.
This afternoon I thought I would have a go at foliating a tree with static grass using my WWS flockbox.
Using Woodland scenics FS618 4mm static grass, I duly spread the fibres on the plate, sprayed the adhesive on the tree frame, connected up and switched on.
Nothing! The static grass remained on the plate. After waving the tree very close to the plate, some of it went onto the tree, but it was hard going.
I then decided to try a different make of static grass obtained cheaply from ebay...... Wow, the grass shot onto the tree frame as if it were magnetic, resulting in a nicely foliated fir tree.
Anyone else had a similar problem?
Hi Rob,Hi Mike.
Short answer, yes. To elaborate, I no longer use Woodland Scenics static grass, despite having a bit 'in stock '. I had an issue using some on Ewe, after I ran out of WWS. Would not stand up. I now use WWS grass only. I'm not alone either, one of the chaps I work for has tried Woodland Scenics static grass on his layout and, like me, could not get it to stand.
In the shop where I work part-time, we are running down stock of Woodland Scenics grass in favour of the WWS equivalent though continuing to stock Woodland flocks etc which are seemingly fine.
