3 LINK
Hi Guys,
Due to some interest shown I have started a build of the Slaters 6 wheeled Milk tanker, I do rate the Slaters kits, the only thing I would say that they do lack is weight. So I have addressed this already by putting some lead in the tank and securing it with Araldite, I'm sure you do not need to see how this is done as I have already done it
before being asked to show the build on here. I have started by building the tank first but this is just my preference you can build it later on if you want, as you can see it still needs some sanding down and filling and I have already drilled the holes for the valves, filler and vents.
One thing I think I should mention, as you can see from the underframe above, there are more stretchers on the left hand side for some reason. I tended to use this as a reference quite a lot as there is an awful lot of brake linkages to fit later and it helps you keep the frame the right way round.
I have put a photo below of the Tanker I am building as there are a few in their range, and although they probably have a similar style of construction I do not want to mislead you chaps in case that is not the case
ATB, Martyn.
ATB, Martyn.
, ahh that's right a certain person requested "loads" of photos
. It's a bit like internal valve gear or coach interiors, but as it's for you lot I have fitted it all in
, so below are just a couple of tips and a few more pictures. In the first picture you will see a couple of locating holes on the axle guards, these usually need opening out but be careful because these holes aid in setting up the ride height and need just the slightest tweak, I use a 1mm drill bit but you could use a broach.
) and finish the buffer heads with a dip in the blackening agent.
