jc2001
I’m seeking the opinion of fellow S7 track builders about whether the S7 mint gauge* will correctly set the gauge widening for fairly sharp curves, e.g. down to 4ft or will I have to add a bit more. If so how much? I should note this long curve is on hidden track and I built it using my own crude gauges and although my 2-6-2 chassis (body not built yet) runs over it very reliably my Heljan Warship Class 42 derails - I think because the gauge is too wide in places. It’s PCB track with only every 2nd/3rd sleepers soldered so it should be easy to resolder with a tighter gauge - hence the question: do I use the mint gauge and simply resolder the rails in a position where it fits snuggly?
*my mint gauge is a milled brass version bought from S7 stores some years back.
Thanks
Thanks
. There may be a table that says maximum gauge widening of such and such but I prefer to see what works. The Peak went around 76" at pace!
