Mine (like quite a few other Parkside builds )juststill needs painting
Now. Yes. That's an interesting subject.
I've got the bits and pieces - chalks, pencils, Paynes Grey, so-forth - but I think it's a matter of knowing *what you are aiming at* when you do the weathering bit.
And, let's face it, the task comes so late in the build that a lot of people are wanting to start something new by then. . .
I would CERTAILY vote for a 'painting and weathering', and a 'how to do the painting and weathering' forum on here!
For those who do not want to guess this is a Parkside Dundas Double Bolster Wagon.... Yes it is being built as an LNER version.
I'm exactly the opposite, the impetus to get through the boring part (building the things)
Hi Simon,
What period and which region / location is going to be home to this model?
....just so we don't upset the moderators.
Simon, it takes something to upset the Flying Squad... colour might be worth a try. Just remember that there is no prize for incurring the wrath of those who (try to) maintain sense and order.
Good move... if you do not get a membership list then please ask Ron Pitts for details of the membership in your area.I have joined the Scale7 group...
I have got patent pending on that! (Barking being a nom-de-sleeper of Gromit)I am going to build a track building jig, along the DogStar plan
What else do you expect from a saw which is circular?.. my circular saw does not cut straight lines anymore...
If you are modelling weathered track, say stuff which has been down for ten years, then the sleepers are likely to have weathered individually so have some sleepers which have been in the dip twice and some which have been in thrice.The sleepers at the bottom of the picture have now had two coats of stain the others have had one. The bottom timber has also had two coats, the top one has had only one so far. As you can see the second coat is darkening quite nicely. I may try a third coat, once these have dried.
Well it is one of those things which definitely does not do what it says on the tin, which ever tin you might be reading...What else do you expect from a saw which is circular?
I bought sleepers from Perfect Minatures, I do not like the idea of ply as they, just seem wrong, IMHO...What wood are you using for the sleepers?
I am using B&Q quick drying woodstain - Oak Satin, we will see how this works. It is thicker than I was expecting so has been painted rather than dipped.What product are you using for staining the wood?
The last lot of sleepers which came my way from Perfect Miniatures were Lime...that takes spirit stain quite nicely.I bought sleepers from Perfect Minatures, I do not like the idea of ply as they, just seem wrong, IMHO...
Having said that I am not really sure as there does appear to be a tie up/in with Model Kit Shop. It got all confusing at one point.
