Simples really, what is the minimum size one can get away with when etching, I gather it's primarily down to the material not the artwork as AutoCAD can go obscenely detailed.
Attached a small part of my current project, it's the checker plate for the foot plate, to the right is near scale, to the left over enlarged to ensure it etches, and the top is a halfway house that should hopefully etch and with the undercut end up near scale size? The lozenges stand proud so the majority of material is half etched away.
Now, I've seen peeps post up images of wagon plates and builders plates which are almost perfectly readable now that means by my guess work that the lettering has to be 0.1/0.2mm thick ?
PPD recommend a ratio of 1.2 to material thickness for minimum sizes so for 0.25mm that makes the minimum size 0.3mm which makes the tread more like Land Rover tread blocks than anti slip grating! I'm trying to keep all this on one sheet to save on tooling costs, it'd be a shame to have to make up another small auxiliary sheet just for these few small parts, mind PPD only go as low as 0.2mm (8 Thou) in NS, mind they do have 0.1mm (4 Thou) in brass so that might be an option.
Would like to get this off this week, only the grating and latch handles to solve which both revolve around the minimum size of etching.
Thanks in advance.
Thanks in advance.
To be fair, I'm fretting over 0.15 and 0.2mm here and there, which are a mere simple brush with a file thickness.
