Hi Tim,
many thanks for your reply. I tried wiring the fan in the same manner as the lights, but the voltage was far too great and unfortunately, the 5V option that is on the MX695 is not present on the MX696 so I think that Plan B will come onto play - don't wire up the fan, you cannot see the rotation anyway.
I'll just tidy the wiring up this afternoon and seal the speaker with silicone and call it a day.
regards
Mike,
There is no 5V option on the MX696S, but it is available on the MX696K and KV. (I know that's not much use in this case, but worth bearing in mind for future, perhaps).
I normally re-use the Heljan fan PCB. It has a small pot which can be used to get to a modest fan speed, then trim if necessay with CV60.
Although, when using Swiss Mapping, it is possible to pre-assign specific 'dimming' values for each individual Function Output. This can avoid the use of CV60 and the consequential need for dimming masks in CVs 114 and 152.
To assign an operating key to FO6 using Swiss Mapping is very straightforward.
Swiss Mapping requires you to first determine an unused SM group. There are 17 groups, each of 6 CVs following in sequence from CV430.
(Group 1 is CV430 to Cv435, Group 2 is CV436 to Cv441, and so on. Each CV in each group has a special function; for your simple on/off switching you will need to use only 3 of the 6 in whichever group you use).
Assuming that SM groups 1 -5 have been used for other functions, the first CV in SM Group 6 will be CV460.
(read your decoder to check that its value is currently 0 (zero) and if not use a different group which is free).
Choose the F key you would like to use and put its number as the new value in CV460 (e.g., if you wish to use F15 as that's the same key as the fan sound, say, then make CV460 = 15)
Then assign the Function Output to that F key:
CV462 = 6 (for FO6 in forward direction)
CV468 = 6 (for FO6 in reverse direction)
That's it.
All wired or harness fitted ZIMO decoders are equipped with shrink wrap insulation. I think they must have tested this system at some point as I've never had a heat related problem with any of the one's I've fitted. LOL.
Kind regards,
Paul
