Simon Glidewell
Whilst building a French prototype turnout in HO, I was wondering how I could make close to scale check rails, i.e. maintain as narrower a gap between the the stock rail and check rail as possible and allow for varying back to back dimensions. I came up with the idea of a flexible check rail made of plasticard with just the outer check rail chairs glued to the sleepers, allowing invisible movement of the rail as locos and stock passed through. This was successful. However, French check rails on older track lend themselves to this method as they are essentially a longitudinal upside down "L" shape. British bullhead and flat bottom rail would be more of a challenge, but could be represented in dock and tram track as only the upper running surface would be visible. Alternatively, actual rail could be utilised. The road/infill surface would be made from thin rubber foam or some other flexible material suitably painted. The plasticard or rail would be glued to the foam outer edges and the foam itself to the track bed. All a bit Heath Robinson I know, but is definitely a possibility for those who do not model in P4 or S7. I will be experimenting with this myself soon and will post some photos.
