Here's my new wheel mount (more commonly know as a piece of wood) with all the spaces filled. This time I made sure to mask all the crankpins with silicone tube before I started spraying. That filter in the booth is just about ready to change now. I've got spares but I gave it an extended lease of life by removing it, putting in a bin bag and crunching and shaking it until a lot of the dried particles were removed. I then gave it a further clean with a small hand held vacuum cleaner. Worked a treat but it's on its last legs now. As I'd been spraying close to the top edge when doing the frames, there was a fair bit over overspray on the light strip. I did a quick check in an out of the way area on the clear cover and found that it was not attacked by cellulose thinners, so was able to clean it up. One thing to be aware of is that when changing the filters a lot of the fine particles fall into the booth. You need to be sure to clean them up before spraying again or you risk getting crap on the work piece. I take it to the garage door and blast it with a hair dryer to blow it all away. I've added a holder to the base on the left for when I'm using the airbrush. So far I've only been using rattle cans, but the airbrush was used to give one of the side tanks on the 4MT a wet coat of cellulose thinners to get the paint to flow out and eliminate some orange peel.
Here's my work space now. Not as comfortable as my original set up at my brothers house, but needs must. The vent from the booth hangs on a hook by the door and if it's raining I part close the door and put the vent in the gap between the door and frame.
Here's the wheels in etching primer drying in the outdoor oven.
And later on ready for refitting.
Bogie and pony truck assembled.
And the reassemble chassis.
Some detail painting with the brush is still to do, but apart from that the chassis is done.
And with the bogie and pony truck placed for the photo.
Having sprayed about 30 model cars during my break from loco building I'm starting to feel a little more confidant spraying the locos and I think the results are an improvement on my previous efforts. Not to get complacent though as captain cock up is always lurking about waiting for a lapse in concentration. For some reason, the top of the chimney has dried matt. Weird!
Speaking of captain cock up, you can see the run in the cab doors me toned previously in this image. I'll have a crack at correcting that today.
Lastly, are rather cruel close up of the back head after painting the brass and copper parts. Some touching up is still required and of course the dials need to be added.
Cheers,
