richard carr
Nearly all the early Heljan diesel models have been known to suffer from split gears. Those affected seem to be mainly the Hymek, and Class 47s, but the other week Scale 7 JB told me his class 26 was suffering this too, and last week we tried mine and yes it has got split gears as well.
Gaugemaster now handle Heljan spares, they list over 800 on their website, so it needed a quick phone call to them to identify the right spare part. For the class 26 (and 33) the part number is 19853582, you get 2 replacement gears for £9 you will need two packs to replace the gears in both bogies. For the original style class 35/47/37 and 55 the part number is 19854780.
Here I have removed the retaining plate for the bogie and you can see the gear that has split on the left, the gear on the right hasn't split yet, but it will in time as the push fit onto their axles is just too tight.
This is the other bogie you can see that the gear to the left of the worm has split on this side
As you don't really need 2 big motors in class 26, the solution for one bogie is simply removing the motor. The other bogie requires taking apart to replace the gears.
To remove the bogie you need to unscrew both the retaining plates located just inside the bogie side frames in the middle of the bogie side, you can see the lower one in the first photo above, once you have those removed the bogie will drop out of the loco body, be careful as you don't want to damage any of the wiring.
Then remove one of the side frames, these just pull off. The inner chassis is held together with 4 screws these need to be removed and the bogie then splits into two as in the photo below.
You can pull out the old gears and take the gears off their axles, I used a wheel puller. You can then easily push the replacement gears onto the axle. The black gear in the photo below is the replacement.
I have pushed a piece of brass into the split gear so that you can easily see the split.
You can then just push the replacement gears back into the gear train
Now it is just a case of reversing the process and putting the bogie back on the body.
