Hello Len,I would like to make this jig for 60' rails, but what is the measurements of the spacers between the sleepers? also does anybody make this jig as I have no way of doing this?
I am not sure which jig is the object of your enquiry... a jig for assembling track or a jig for cutting rails. That you mention the spacing of sleepers suggests that you are interested in the track assembly jig and I shall reply accordingly.
The track jig that I have made for 60' rails is for LNWR track circa 1900 and hence the sleeper spacing is that for the LNWR... there is a drawing of a LNWR 60' track panel in the "LNWR Liveries" book from the HMRS. Other railway companies used 60' rails, as did British Railways, and hence there are variations in the numbers of sleepers per rail length / spacing between sleepers. I can provide the LNWR info.... I do not have any info for later track details (although I suspect that users of Templot might be able to assist).
The track jigs that I make use wood sections that are to be found in most garages (at least garages of those who confess to some level of DIY experience.... yes, yes, those at the back of the class can claim that they practice DIM instead). I make the jigs whilst modelling on the dining room table and the tools are nothing more fussy than a tenon saw (to cut the chipboard/MDF/pine to length), a Stanley knife (to cut the 1.6mm ply into strips) and a steel ruler. Having the sleepers to hand is helpful in getting the spacers cut to the correct width (sand the edges of the spacers for a sliding fit).
Otherwise, nothing tricky, just ensure that glue is kept out of the sleeper slots.
bought the wrong ones.
