Rambler
This ABS Zero Zephyrs kit was the first loco kit I bought when I made my first steps in 7mm, in 2005. Its the sort of thing that IMHO is just too small to work in 4mm but should be ideal in the bigger scale.
I didn't actually start building it until 2016 when I came up with the scheme shown below for powering it. This uses an ABC gearbox with a Maxon 2W motor in the firebox, in place of the suggested 1620 Mashima and worm drive.
So here are the frames being prepared. I've got the rear axle rigid in the chassis and the front axle able to slide up and down. At this stage I'd worked out that I needed to have the axles slightly higher in the frames in order to get the buffer beams at the right height - photos show that the buffers should be at the top of the buffer beams so that they are almost level with the footplate (see diagram above).
