.... I have just measured mine against the dimensions sent to me by Neil (from Parkin I think) ....
Just for interest, I've measured my coaches up against the measurement quoted in the G1MRA fast forum - 127mm from railhead to top of water filler. My coaches measure 121mm for the same dimension. The dimension should equal 12'7" which is 120.29mm in 1/32 scale.
I put mine next to a known, accurate 10mm version yesterday, the difference is, unsurprisingly, noticable
In other news, an answerphone message this morning puts the dimensions of the step above the gangway as protruding 7 1/2" out from the flat face of the end and being 45" wide. Roughed out, thats 6mm x 36mm, the model measures out as 11.5mm x 39mm, time for surgery.
Steve
They definitely looked wrong on the coach as supplied - I wonder how many will get left as they are?
I think lots of people will cut them down because they make an audible clicking sound even on 10 foot radius curves....there are a few sets on their way within my local group and all are destined for selective trimming.Brilliant Steve, time for a bit of cutting!
I shall do the rest after I've been shopping...I must say the visual improvement is immediate and dramatic, big return for little investment!
Apologies for the slightly Heath Robinson approach to making a height gauge, but by using a couple of squares and a couple of rulers I reckon the height from top of the roof to the bottom of the plinth is just over 79 mm. Assuming that the target measurement should be 79.63mm (8'4" if I've understood correctly) then the plinth should be included in the height of the side and if it is, the overall measurement is with 0.5mm. Or should we discuss whether I should have included the height of the ribs
No need Jim, one measurement was from the top of the roof to the bottom of the plinth, so its just the body side that was of interest. When measuring the overall height (rail top to water filler), that was done with it on a piece of trackHave you allowed for the height of the wheel flanges?
Jim.
That two of us with the same result then, excellent. I've decided that dimension wise its plenty good enough for me, time for individualisation (and running, lots and lots of running).I think Steve did Jim, as that is exactly the result I obtained when I measured mine on the track.
