Upgrading the Accucraft Adams Radial Tank
Discussion in 'G1/32' started by Thirtysecond, 27 November 2020.
  1. Thirtysecond
    Thirtysecond Western Thunderer
    Well, to Chris Tolhurst and I the Adams Radial tank is second in Victorian elegance only to the Adams T3. Accucraft bought this model out in a variety of liveries and with the two boiler variants earlier this year. The model being gas poker fired limits what could be done in terms of improvements to our two models but even with that restriction there are many areas, cosmetic and working, where there's room for "polishing". Here is one of the two models when finished.
    F00F420D-4A87-4EDF-AB8B-302E4932E7F7.jpeg 4F7C1635-0474-4B55-BFFB-C92098C98959.jpeg
    If anybody's interested I can go through some of the things we did which included:
    Add cylinder drains and dummy drain cocks
    Improve the chimney
    Add an Enots valve
    Draw file the coupling and connecting rods
    Improve the look and fit of the coal load
    Increase gas capacity
    Move gauge glass and its drain valve
    Move lubricator tank
    Add a detailed, glazed cab with a scale reverser
    David B, Keith Phillips, AJC and 6 others like this.
  2. David Halfpenny
    David Halfpenny Western Thunderer
    :) I'm interested in how you did all of it, Derek !
  3. Thirtysecond
    Installing Cylinder Drains
    There is a convenient groove in the cylinder blocks which, with a sliding rod added, and ports drilled through to the cylinder ends, formed the basis of cylinder drain valves. On the real thing there is an external rod which operates the drain valves. This is not on the model and had to be added. A linkage was taken through to the cab via a pivot crank on the weigh shaft. The linkage operates both the working valves and dummy drain valves. In the cab the drain operating lever was replicated exactly.
    E2638867-3CBE-412E-B355-0BE208F6D4EC.jpeg 02830F49-9B65-477C-A323-9FB034C29BAD.jpeg 37AB1EB7-0D0B-44CA-8FEF-4269D9366F1C_1_201_a.jpeg 5114B01D-3635-49BC-8DD6-BCC2D8B913F6.jpeg B3EB7FDD-DC67-4727-822C-529AA132412F.jpeg 1F9CDFEF-E065-459B-8AEE-D6C407B2FCD7_1_201_a.jpeg View attachment 133851 7C83E544-1B86-4933-972E-4FF2D8CE40E5.jpeg
  4. Thirtysecond
    Better use of the bunker space:
    Improving the scale look of the cab:
    David B, AJC, oldravendale and 6 others like this.
