A big thanks to all who have helped. Warren Haywood, Steph Dale, Simon Thompson, Laurie Griffin, Diane Carney, Peter Smart, Mike Sheardown, Stuart Tebbett and John Craig. And of course all who have contributed via this thread.
Out of interest, is the regulator handle on a T9 really that titchy? Drivers must have had enormous upper body strength to move a regulator of that size.
Dad,
Yes, that's the size of it; one of the things we checked. Actually Drummond was an early exponent of balanced regulators so wouldn't have needed a gorilla.
Here are some pics of the ongoing W1 Tenders They're Dave Andrews ones. I've detailed up the inner chassis with a representation of the well of the water tank. All the water scoop and operating rods are present and the water shields for the brakes and axle boxes are modelled. The brake rigging has been re worked a lot too.
The hardest bit of the whole build is forming this fold in the tender sides to the correct profile and in the right place.
...It's been a while since I updated my blog. The tender build has been pretty straightforward. The old Dave Andrews kit is still a goody. It fits together very well and is adaptable to all the variations of this tender. The tender the W1 had in it's last decade or two had no beading along the top. The beading is etched into the tender sides on the kit, but I used them inside out and ground the beading off, except for where it re-appears inside the front of the tender. There is not much in the kit for the tender front, so a lot was scratchbuilt. There is a contraption (designed by Heath-Robinson) that indicates when the water tank is full and the scoop can be withdrawn from the trough, and a lot of lamp-irons and brackets for fire-irons etc. to add. The water filler area has been embellished by the addition of a lot of angle iron and some detail to the water filler cap. It has a closure that works like that on a kinler jar (not in kit!)
When I fitted the chassis (outer) in place I elected to use the narrow (correct) position, and this impedes the fitment of the buffers. The Gresley tenders have steps fitted to the frames and not a convenient back plate to hide the springy, nutty gubbins on the rear of the buffer. I had to concoct a (Heath-Robinson!) method of making the working buffers have self contained springs. Here are some pictures showing how I did it. I'm sure you can work it out! (sorry about the poor photography!)
....I have finished the mechanism for working the water scoop. Next, finishing the brake rigging. Still a bit to do but the build has been a pleasure because of the good kit quality. Not a huge number of detailing parts, but that makes it a blank canvass.
Nick, I've read through your T9 build(s) over the last few days and I'm in complete awe with the quality of the workmanship and attention to detail. T9s , all be it in later BR condition, are one of my all time favourite locos and your build has done them proud. Well done that man (and helpers). I just hope a small percentage of your skill rubs off on my efforts.
