Len Cattley
That sounds good.
Nick,
After our discussions and research toward that linkage and contraption I found this yesterday on the web
DSCF0242 by Rail Simulator, on Flickr
Proof...as if we ever needed it
We weren't talking about the handle, we were discussing the label underneath in relation to the funnel to the right and linkage below.This handle has nothing to do with the water pick-up, it's used to open the "cods mouth"
OzzyO.
Absolutely correct, but at high speed by the time the water level got to the top of the tube it was too late, so the LNER 8 wheel tenders had an extra overflow pipe set to siphon water off into the funnel when the tank was nearly full, then the water scoop could be lifted before it over filled.The small handle near the top of the tube was used to indicate the level of the water in the tank by rotating it so that it was parallel to the coal face of the tender. It then had a set of small holes that would let water out in line with a set of markers on the tender side. You can see the top marker just below the handle. When the tender was full from using the water toughs it would come out of the overflow at the top of the main tube.
OzzyO.
Hello mikoo,
You have a double headed train and both locos want water, who dips first? and why.
OzzyO.
I have this picture (bottom left)
http://www.model-engineer.co.uk/sites/7/images/member_albums/93892/618573.jpg
But wondered if anyone had a pic with the cover on?
No photo I'm afraid.I have this picture (bottom left)
