7mm A Bristol L in 7mm
James
This shows there's a bit of variation in the quality of the parts. I think the steering wheel is salvageable but a lot of the small resin components will have to be replaced.
James
A bit of work on the bus this afternoon.
44mm x 18mm planed timber was used to fashion a slightly crude former to help with straightening the body.
The sides should be up against the former, it shows how distorted the body casting is.
I dip in boiling water made reshaping easier and the result is better than before but not perfect, far from it. The roof has been straightened but there's still a lot of fettling required.
It's not the worse kit I've seen - that honour goes to a Wheelbase Models London Transport trolleybus which was like a carved bar of soap. Think I still have it somewhere... The Bristol L is the second worse bus kit I've experienced. If I wasn't building it for a particular purpose I would probably cut my loses.
James
A bit of a fitting exercise over the last couple of days, the roof now fits nicely against the rear panel.
Elsewhere...
The roof has needed a strip of 40 thou Plastikard and a substantial quantity of Milliput to allow the to join all round. I'm not sure if the roof is out or it's the body that's lopsided.
The cab door being offered up to the cab.
Hopefully I'm slowly getting there. But I have, as of today, exactly a month to have it ready!
djparkins
Elsewhere...
I'm sure you'll do it James.
But watching your build, I'm sure glad I sent mine back!
DJP
Plan B New
James
I have officially abandoned the Scalelink kit.
When I was marking out for a new cab in Plastikard to replace the warped original (warped in so many directions correcting it was nigh on impossible) I figured scratch building might be the better option. The Scalelink wheels, seats and etched window vents can be repurposed.
I had borrowed a book from dad has decent drawings, the suitable one was scanned and printed out to 7mm.
By finding an alternative approach hopefully means I won't have to resign my membership of the Model Bus Federation!
robertm
Sorry to hear you’ve given up with this model, but as I’m sure you would agree it is diabolical.
Does the book you’ve shown have a plan for a Bristol Double Deck bus c1950? I fancy building one from scratch.
Perhaps I’ve got the only completed Scalelink L5G
Bob
djparkins
James -
Sorry to ask but does that book have drawings for a Bristol Lodekka? Happy days on the old 38 route - Salisbury to Bournemouth
Thanks,
David
JohnG
James -
Thanks,
David
Hi David,
I have the same book, I picked up a absolute cracker for £3.51 inc postage, unfortunately it doesn't have Lodekka drawings in the drawing chapter, it does have good detail history and good photographs.
Ta, John
djparkins
Hi David,
Ta, John
Thanks John
Osgood
I need to come clean , more evidence has just been received.
That apparently was the initial firing cycle - this is what then ensued (it did eventually settle down to a nice clean tick-over, honest):
Screenshot 2024-05-25 at 22.45.01.pngScreenshot 2024-05-25 at 22.45.12.pngScreenshot 2024-05-25 at 22.45.24.pngScreenshot 2024-05-25 at 22.45.46.png
Good job nobody was waiting at the bus stop.....
