richard carr
Well done Brian, I didn't realise from reading the earlier posts that that was the required solution, its a bit of bu**er to say the least.
So, the moral of this story is to not bodge and go for what appears to be the most difficult route to start with.
In this case I would have approached it in the same way but instead of matching a curve to a curve I would have scribed the curve onto a new piece of brass for the outer edge and cut the old frame edge square to make the mounting of the new section easier.
I'm sure you are correct, which is one of the reasons I asked for comments. I think I'll just have to take another look at the GA and see if I can make any more sense of it. Of course, it may be the kit design, but I can see no means of locating the cross shafts in to any sort of bracket apart from the obvious one on the outside tender frames.It looks better and I know nothing about K tenders but based on other air braked tenders it can't be completely right.
Happy to, send it through. I am heading off to the beach for a week so will have limited Internet but shouldn't be a problem.Thanks Overseer.
I'll look at the potential for simplifying the set up. Wonder if you'd have a look at the drawing via a PM to see if you can make head or tail of it?
Brian
