Hi Guys,
I also gave in and brought one of these 08 things, I must admit there is something appealing about them, kinda cute in a weird way. Anyhow on inspection my eye was immediately drawn to the horrid brass spacers, some folk might be happy just to blacken them but for me they had to go. On further scrutiny I also noticed the quartering was well out and there was no speedo drive, so hopefully I can correct all 3 things at the same time.
There is nothing new with the method I have used to make a puller to remove the cranks, a chap from over " there " started the ball rolling by making use of a section of 22mm copper heating pipe, I started in a similar way but used plain old 13mm cooper tube. Well the cranks seem to be made of a light metal possibly alloy? and the axles are steel which is a good thing because as delicate as I tried to be when pulling the cranks off they did need a certain amount of welly, so much so that it distorted the tube/puller! The first side drifted off quite easily, but the other side for some reason was a nightmare, the captive nut was just pulling out of the solder on the tube under the strain. So I thought I would try some rectangular brass section I had instead of the tube method, well it did the trick and the drive axle crank actually came off with a resounding crack!
This job took a lot longer than I anticipated, but I was not going to be beaten, it's family time tomorrow so hopefully I will make a start on the rebuild next week sometime.
The two pullers......
Cheers,
Martyn.
