Recent activity has been focused on making a 1:8.25 crossing for the turnout which connects the up loop to the up main, turnout 4A on the station plan (
here). Whilst the construction of the crossing has been covered in the Permanent Way forum (
here) that thread was left with the common crossing waiting for installation on Hartley Hill.
The first photo shows the completed crossing sitting on the template on the baseboard with black permanent marker on the free-ends of each rail ready for aligning the tip of the vee with the relevant timber and then marking the rails for cutting to the appropriate lengths (scribe a light line across the rail / through the black marker). The brass strips which hold the crossing together have been cropped approximately, the pieces are filed flush with the wing rails after the crossing rails have been cut to length.
The crossing with all free ends cut to the correct length. The block chairs for the vee have been formed and fitted... whilst at the other end are shown two plain line chairs fitted temporarily to gauge how much needs to be removed from each chair.
The two plain line chairs which are combined to form the LNWR "6" chair are now the correct size to join together - the chairs are shown displaced from the correct position (where the chair sits central on the appropriate timber) so as to show where the chairs were cut /filed to size.
And here is the result after the chairs are moved into the correct position and joined by use of solvent.
This is as far as construction goes before the crossing is fixed to the formation for the remaining chairs are either singles or half chairs.
Fifteen photos after construction started, here is the complete crossing for turnout 4A. Plain chairs are cut in half to provide a chair jaw with key and are then applied to each side of the crossing ( at positions marked as X, A and B on the template). The dropper is hiding under the vee, to the right of the timber beside the letter B).
Just visible in this photo is the start of plain line track (out of focus fishplate to right of centre). By the time that this turnout was renewed the LNWR had introduced the "Bridge" chair and that type of chair is adjacent to the rail joint.
For those with a "PW-S&C" anorak in the cupboard, the LWNR had changed from 14" to 12" timbers at some point between circa 1900 and circa 1909 hence there is a visual difference in the timbering between this turnout (4A) and the previous turnout (4B) which was covered in
this post. Similarly the introduction of the bridge chair had a significant difference in appearance and chairing of the turnout (no narrow plain line chairs in this turnout).
