Ressaldar
As a diversion to having the prostate problem on my mind, I decided that a BLT layout would be in order and to make things different, I would do it in 4mm. So I sat myself at he laptop and opened AnyRail and had a play for a couple of days with various ideas and eventually settled on a design. The location for this new layout was to be on the opposite side of the workshop to the O Gauge layout and would require some planning, especially as the fiddle yard would be slap bang over the current (but unused for quite a while) workbench, also that a large wall cupboard would need relocating.
However, the best laid plans........................... the 4mm idea was thrown into touch and a much simplified 7mm working diorama evolved
The workbench problem was soon resolved as there is a worktop which spans the width of the workshop located immediately behind the front door and sits on top of two side by side cupboard units. The idea was that the new layout would bear down on the worktop and then be supported by the relocated wall cupboard which would have suitable bearing struts screwed on to take the width on the layout. The only restriction was that there is a one brick wide pier that had to be negotiated/incorporated into the design, resulting in this working diorama plan…………………
The baseboards are now completed and the track has been laid on the scenic board
with wiring to follow in the next few days, certainly before next Monday which marks the start of my radiotherapy, so there is the possibility of no meaningful work being done for the next four weeks – we shall see.
regards
regards
