Mike Garwood
I've been lurking in the background for a while now. Lovely to see some of Larry's work on here and some of the 7mm work is very special indeed.
So I model in P4, that does not mean I'm any good, it just means I don't have time to build in other gauges at the current time.
So these are a few projects I finished over the last few months - having been off work since Feb.
First, Britannia Western Star 70025
Still the bellows to put in, it does run very sweetly. Comet chassis, sprung throughout, including the tender.
When I retire I'm going to build Hengoed High Level station and yard. So I ditched all the Mk1 coaches that I'd built - except one - more ofthat later. So I set about building my fleet of engines for HHL.
High Level chassis, compensated.
Comet chassis, Brassmaster bearings and springs.
And finally a pannier.
I've tried to lightly weather all, some with success others will need a lot more work.
And finally...Mk1 Brake third. When I built this some years ago it appealed to me (probably said "help!). So I kept it. When Rumney models launched their range of sprung bogies I got a set. Truly the dogs! They are not to be rushed (you can't anyway) but the end result is something else.
I've also finished a couple of GWR fruit vans and am currently building a 2251 class engine and tender.
Of course I should have realised the wheels would rise in the chassis once the weight went on, so more fool me.
