Thanks Larry, I agree about the curved running plate, although with the Flower having straight plate it's got a presence about it, that's the next body work to do.The curved running plate 4-4-0's were always the more attractive IMV. This model is coming on stunningly.
Thanks Jan, that's the great thing about this forum is the ability to share our work, and I'm always picking up ideas from other members builds.Hello @Hobbyhorse
Lovely work. An exemplary rendition of observation, skills, and fidelity. Your dome securing solution is very neat.
Jan
Hello SimonThanks Jan, that's the great thing about this forum is the ability to share our work, and I'm always picking up ideas from other members builds.
I'm not the quickest builder as I enjoy the journey and challenges that kits throw up.
A friend was over a week or so ago and we had quite an in depth discussion about what we get out of the Hobby, his was building layouts and all that goes along with it, so needing a reasonable amount of stock quickness of build with some RTR was important.
I suppose the most important thing for me we talked about is the workshop, with the tooling to create the models.
It'll be interesting to here other members views.
Hi Hobbyhorse. Is it possible to explain your washout jig?One thing that needed some extra work is the washout plugs, provided in the kit are two etched strips which has 3 plugs on each, lacking any depth obviously. With the three kits having the same some 34 individual plugs are required, so it was worth setting the capstain lathe up to produce the body, and the mill to cut the square section. Fitting them was quite easy once a small jig was made to hold them from the outside aligning then exactly.
Although the Duke kit doesn’t have the boiler bands provided in the kit, I’ve taken the decision to fit them to be consistent with the Flower and Bulldog that has them etched on, cut from 5 thou nickel silver and once fitted the hand rails were added.
The back plate provided in the kit gives a lot of options for the fittings, so working from a photo of an original build those required have been cleaned up and had the copper piping attached. These won’t be fixed until the back plate is painted and the brass edging added.
Hi I had the privilege when I lived in Bristol to visit Tony Reynolds workshop many times . I would be very intesting to see pictures of your workshop if you are happy. I am more a builder that running trains, although I am about to start building a layout in my retirement. The neighbours keep asking how's it going. But they look disappointed when I say it will take 10yearsThanks Jan, that's the great thing about this forum is the ability to share our work, and I'm always picking up ideas from other members builds.
It's basically a aluminium plug that fits into the opening on the boiler with a small hole that allows the square section of the plug to fit into from the inside, insuring that it's a puss fit on with hold it in place while soldering, and being aluminium it doesn't attach it self.Hi Hobbyhorse. Is it possible to explain your washout jig?
Thanks
I'd rather not show photos of the workshop but it's similar to Tony's.Hi I had the privilege when I lived in Bristol to visit Tony Reynolds workshop many times . I would be very intesting to see pictures of your workshop if you are happy. I am more a builder that running trains, although I am about to start building a layout in my retirement. The neighbours keep asking how's it going. But they look disappointed when I say it will take 10years
Completely understand.I'd rather not show photos of the workshop but it's similar to Tony's.
thanksIt's basically a aluminium plug that fits into the opening on the boiler with a small hole that allows the square section of the plug to fit into from the inside, insuring that it's a puss fit on with hold it in place while soldering, and being aluminium it doesn't attach it self.
Simon,Onwards with the Flower body last week. The running plate and boiler went together without and major issues as you would expect with these kits. I’ve fitted the replacement washout plugs again which was interesting fitting in the boiler sections, with limited access.
The replacement for the Dremal and hard soldering equipment arrived.
Very impressed with the Pendant drill, its well balanced and much more user friendly.
The hard soldering equipment I went for is an oxygen/propane set, with micro burners and its also suitable for larger jobs and braising.
In use it’s a very different beast that’s very controllable for the smallest jobs, but very powerful that’ll still melt brass very easily if your not careful. Using it with soft solders is very easy and quick. New to me is a liquid flux used in the jewellery trade that works well on brass, nickel silver and steel. It’s easier to use than easyflow and borax, and is non toxic without the deposits with the powder fluxes.
Mick, the hand piece is from Badeco (collet type) and the motor drive and shaft from Pioneer (20000 rpm) I did have a Proxxon set up and a dremal which both expired. This has no comparison with the old ones, for me its the hand piece size which is small and no vibratio.Simon,
Which pendant drill did you go for, I currently use a Proxxon drill but with the extension cord attachment, it's light in the hand and very easy to use, the problem is the chuck which is not up to the quality of the actual drill chuck, despite both being made by Proxxon.
Proxxon Flexishaft 110/bf
Proxxon 110bf Flexishaft is a dual precision aluminium tool holder with dual ball bearing steel shaft.Proxxon 110BF Flexihaft has a h.. - Product Code : 999 3308 , Price : 25.44 GBPwww.cooksongold.com
