oldravendale
Thank you Dave and Mick for the additional and clarifying info. Regular watchers of this thread will note that I've started to incorporate new info and corrections in the commentary accompanying the photos. The reasons are two fold. Firstly we get a full description attached to the photos and secondly I can just copy this on to the file for each photo instead of having to collect the info together during periodic housekeeping. Please all just keep the additional stuff and even more importantly corrections coming!
Jubilee 45631 Tanganyika on arrival at Euston on 6th April 1962. It was a Crewe North engine, moving to Saltley in March 1963 where it was withdrawn in August 1964 (SLS) although Rail UK and BR Database advise wthdrawal from Crewe North in August 1964. There is general agreement, though, that it was scrapped at Cashmore's, Great Bridge, at the end of 1964.
A gratuitous and unidentified Britannia probably photographed while winding the film having loaded the camera. I suspect this is from the Kenton Recreation Ground on 6th April 1962. I believe this is on the West Coast mainline and the loco is on the slow lines heading south as there appears to be the end of another train on the fast lines heading south. My evidence for this is the cable conduits look very similar to those in earlier posts of Kenton and South Kenton and the distance between the cable conduit and the loco is not great enough for the two electric lines.
A reason for this not being on the Met & GC is the cable conduits on this line are on the far side and not visible from Northwick Park. Added to which if this is 70021 Morning Star she was a Willesden based loco around 1962. it appears there is a hut or building in the background and house chimneys - perhaps the following photos in the sequence on the same negative roll may shed more light.
The Britannia is interesting. Whilst the cab image is incomplete and thus isn't obvious whether it has a BR1d or a BR1a tender, the name plate is probably two words with the second being rather shorter than the first. The 'stars' 70021, 25, 27 and 29 would fit. Polar Star [26] would have had altered deflector handrails in 1962 following the Steventon accident so can be excluded. The coupling rods are the non-fluted type and the connecting rod is fluted so that might also help.
I fully endorse Arun's assessment. The finger is pointing fairly firmly at 70021 Morning Star. The other three 'Stars" had all had the revised WR smoke deflectors with handholds rather than handrails fitted prior to 1960. 70021 also had the plain coupling rods and fluted connecting rod as Arun describes.
An unidentified Fairburn 2-6-4T on an up local train at North Wembley on 6th April 1962.
Princess Coronation 46246 City of Manchester on the down Royal Highlander Inverness Sleeper at North Wembley on 6th April 1962 with the Wrigley's factory in the background. This was a Camden engine, withdrawn in January 1963. (SLS). It was scrapped in Crewe Works by the end of May. (Rail UK).
Here's City of Manchester again, but this time at Euston on 8th April 1962.
Brian
Brian
