Wantage Tramway Jane No. 5 in 4mm
Bigjohn
Simond
Not sure of the exact science or logic, I would never rotate a reamer but only use uni directional. I have never understood the use of jobbers drills in an Archimedean type holder. A spade type drill is appropriate. Perhaps it goes back to only using a file or hacksaw in the correct pull/push mode. It just seems illogical logic if that makes sense!!!!!!!!!
michael080
Simon,
a slippery slope, this is not my native language, so broaching and reaming may need a closer definiton.
https://shop.machinemfg.com/drilling-boring-broaching-and-reaming-key-differences-explained/
is quite informative.
My understanding is that a broach is used to push a specially shaped hole into an existing (round) hole.
https://cdn.hoffmann-group.com/derivatives/203065/jpg_600/jpg_600_b290406.jpg
A reamer is a tool that rotates like a drill bit. It is used to finish a hole to a certain diameter with a certain surface quality.
https://cdn.hoffmann-group.com/derivatives/45512/jpg_600/jpg_600_g160100_a.jpg
Referring to my earlier post, I should have written "I learned that a reamer must never be turned backwards."
King Crab
Hi Ade
I am trying to put together a Shannon model too.
So I went to Didcot and crawled all over the engine, taking snaps of all the bits that I couldn't understand from the drawings.
Including underneath!
I have put around 80 of the photos on the Wetransfer site, totalling about 35MB of files.
Just Click on the link to download.
I only have a free service so they are only available for the next three days.
If you don't manage to catch them in time, let me know and I will upload them again.
If anybody else is interested, feel free to download.
A sample image here of the backhead:
Simon,
Ok, Michael, we’re on the same page!
the reamer is a forward facing cutting tool, typically cylindrical, of precise diameter, (though hand reamers will have a taper of maybe one third of their length to assist entry - machine reamers will only have a chamfer), and generally used as a finishing cutter. Whilst I doubt it’ll do any harm to turn it backwards (apart from very local work hardening of the workpiece perhaps) it won’t cut if you do.
The broaches in your illustrations are what I was referring to, and are longitudinal cutting tools.
the pentagonal ”broaches” that we‘re discussing are neither, so they are probably ill-named.
Something like “tapered multi-faceted bore scraper” perhaps :)
Overseer
Did you measure the cylinders? Both versions of the MRJ drawing have very oversized cylinders, as does the earlier magazine drawing. The 1947 GWR diagram is more accurate. Just something to look out for.
spikey faz
Hi Ade
I've just had a scoot through your pictures. Great wealth of detail there for anyone contemplating a model of this locomotive.
King Crab
I didn't put a measuring tape over the cylinders, sorry.
Thanks for the heads up.
AdeMoore
Hi Ade
Sorry Peter just logged back in to the thread, I missed a load of posts here! My notifications don’t work half the time for some reason. If you wouldnt mind sharing the link again I’ll keep my eye out for your post.
Much obliged.
AdeMoore
Might be closer to getting the chassis in the jig after a few more hours done. Where does the time go!
So the dilemma was 2 coupling rods with oval holes soldered in with brass tube, no knowing if the 4 x bits of brass tube in anyway lined up. The ovals originally filed out to get the chassis to run were pretty generous!
The crankpin brass bearings for want of a better word are 1.5mm OD so the new reamers were set to work as you helpful chaps advised.
Working from both sides works, so you can keep a good 90 deg to the piece.
I didn’t have a 1.5mm in my set closest was 1.6mm I accidentally went all the way down. Ah! I rolled with it making sure the other end and one on the next rod were 1.5mm by using the vernier and marking the shank with marker pen.
Then the fun and games trying to judge a centre on the last end to make a matched pair!
By eye I drilled a 1mm hole central as I could.
Then using a 2.3mm reamer which fitted the hole I scribed an arc!
umm off centre. But then I realised the brass insert I filed up In the drill was not perfect in the hole, so I superglued that in and repeated the proces.
89B3CCDB-650E-426E-8427-DBE868DBD2B5.jpeg6663A433-65CA-47EC-8EFD-08159263A351.jpeg692AD94D-2302-4298-81AE-56FE95DC8BD5.jpeg
That looked like luck was on my side so in with the reamer on the last hole.
Sat them on the jig then found Id lost a crankpin bearing in the intervening years to now!
I had 6 think I destroyed 2 filing them down . See if I can find one or make another!
Thanks for your likes and interest.
More soon.
AdeMoore
Progress has slowed, not that it was ever anymore than glacial!
The Markits crankpin bush has been lost X 1.
As I thought I butchered 2 of the 6 I had in the early days!
Searching online Wizard appear to have them but silly price. Bob a Scalelink showed an image of a pack but after an email exchange I found out Mark the proprietor of Markits had sadly recently passed away. Bob has no stock, and Marks widow is yet to decide on if or when anything will be sold up.
I think I can make one a sleeve maybe rather than a top hat version.
Just need to find my tube stock.741FA60C-8B85-4104-9CA8-71A58B28B7C2.jpegDE92DE3C-B150-4F79-869B-F9193CC81A9C.jpeg
View attachment 234593View attachment 234594View attachment 234592
More soon.
Ade,
in your picture I can see both rods on the same end of the extended axles. This may be ok, but can amplify any errors in the axle spacing in your chassis,
Once you’ve established that the rods are the same, you really want the rods one on each end of the axles, to set & check the chassis to the rods.
hth
AdeMoore
Ade,
hth
Cheers Simon, yeah was aware, I just launched the rod on with the other as I’d lost the bush! Just to give an inclination as to roughly matching centres.
So once I’ve made another crankpin bush I’ll put the 2nd one over on the other side. Stick the vernier on em and see where we are, I doubt they will be dead the same somehow!
But we’ll see..
Thanks for keeping me on the straight and narrow.
King Crab
Much obliged.
Ok
I've uploaded all the Shannon photo files to Wetransfer again.
here's the link:
Available for just three days, hurry now!
