I have finally got round to finishing "Terrys Preproduction" 7mm 32mm gauge plug track kit. Firstly can I say this was Terrys first entry into 7mm kits and was the basis and learning curve for the production versions, Firstly its has a 6mm ply base, production kits use 3mm ply
Terry has revised both the check rail chairs and here the switch PL3 & 4 chairs making them in halves to ease the build method. You can see the two PL half chairs on the straight switch rail, saving a lot of effort threading 2 rails in to two double chairs
The switch rail partly pushed into place
Like wise the check rails have their half check chairs threaded on
And easily pushed home, for me a much easier method than using loose jaws
The completed turnout waiting for some electrical bonding wires, then I have to find some board to mount it
A very quick test and as you would expect the loco ran smoothly without any fettling
This is the production version made from 3mm thick fret which I am about to try using some FDM chairs (once I have printed them).
A first class kit at an affordable price available in 4mm scale as well as 7mm, now also in S scale. £25 for a 4mm kit £35 for 7mm, rail is not included
www.kosmik.co.uk
