They may well do a GER version, I say that as the instructions show mostly a GER model being built and there appears to be (some) castings for said version. This kit (LK18) will build the industrial version and GER versions 209 - 210 which I suspect are the very early Neilson open cab versions that the GER bought. I've not had chance yet to see if there's another kit for the other GER engines; I'm really tight on time to get it away by this evening.Thank you Mick.
I didn't know Ragstone did a kit of this particular locomotive. I'll check it out.
Your point about the additional parts and associated costs is noted.
The one I'm doing is one of the four Stratford builds that came later. As far as I can tell there were four Neilson builds and four Stratford builds, the Neilson ones were modified later to the Stratford design, but almost certainly not identical; pictorial information is scarce so it's logical to impart a bit of common sense engineering of the day to get what you want.
