Soldering fumes
DavidB
Many of us tend to be rather blasé - I certainly have - with regard to fumes, often thinking we are only doing something for a very short time, like soldering a joint, and they will be gone. I have spoken with more and more people who are either sure or think they may have done some harm, temporary or permanent, to their lungs. Fumes from solder is only part of the equation; flux fumes, especially if you use an acid, can be equally or more harmful.
Fume extractors are available, many at a price because they are aimed at the professional market where people spend long periods at the workbench soldering without the breaks we have reading instructions (which I am sure everyone does very conscientiously) cutting, filing, fitting and picking pieces off the floor. This leads us in to a false sense of security.
I have adopted an approach which, whilst far from perfect, may help and costs little to make and try out. I first saw the idea some years ago and have been meaning to get round to it ever since.
I set up a computer fan on a wooden base, used a 12volt, 2amp plug transformer and inserted a simple switch. I am no electrician but even I managed this (eventually). The fan came from an old computer going to scrap and cost nothing; the switch was less than £1, the DC plug socket about £2 and the transformer £5.99. Total cost less than £10.
It does make a little bit of noise, but no more than a computer and it is easy to switch on and off. The draft appears sufficient to waft fumes away from my face without blasting everything on the bench on to the floor. I also use it with Mel/Plastic Weld. I don't think it can replace a proper extractor unit for spray painting, though. I pass the idea on for others to think about.
Chris Veitch
I’ve been considering an extractor for my bench when my workshop move is complete. I’ve seen them discussed for solder fumes on some plastic modelling forums, which is rather ironic given the time those guys spend swimming in solvent fumes…
I’ve not seen such a thing, but I’d have thought it would be practical and cheap to put together a custom unit given the availability of 3D printing, cheap sensors, Arduino control etc. Anyone know of anything like this?
Lawrence Boul
It's broadly true that effects are determined by exposure level, frequency and duration. Exactly what that means will vary enormously with the damaging agent. Your fan is presumably reducing the exposure level by diluting fumes in the room air.
For those interested in established risks, commercial products will have an available MSDS (material safety data sheet) that will list risks, toxicity levels etc. The toxicity of solder is probably negligible via inhalation, ingestion being the problematic route. Flux fumes would be the larger issue. (But how careful are you with your filings, do you wash your hands, avoid eating at the bench and so on?)
I generally take the view that contact with or inhaling chemicals is best avoided, not that I always do.
Another thing to bear in mind is that risk perception is extremely subjective and is impacted by things like perceived control. Thus most of us feel more anxious in a plane than a car despite clear stats that the latter is far more hazardous. This can lead to us over or under estimating hazards by a considerable margin if relying on intuition alone.
The risks of soldering, spraying lacquer thinners etc are documented as are recommended precautions. Anyone doing such things should really read the material and behave accordingly. Unfortunately it's not particularly accessible to the average hobbyist nor is it always easy to take the recommended precautions.
If anything the fumes and vapours from soldering and the solvents we use are more likely to aggravate allergies and/or skin and/or internal membrane sensitivities.
Lawrence Boul
I'm not qualified, and this isn't the place, but I have no doubt that is broadly true. Printing resin sensitivity is a known hazard and, given the number of people I know who have experienced symptoms, not uncommon. Not life threatening, generally resolved by avoiding exposure, but unpleasant and inconvenient.
Flux fumes are a well-known irritant, which can cause asthma. Our assembly operators have individual extractors on their soldering irons, leading to a manifold and outdoors to a fairly chunky centrifugal fan, but there are 5 people soldering several hours per day, so it’s not really “lone modeller” terrritory.
We use a local PCB manufacturer and they have individual extractors with an angle-poise type arm and local filters under their workstations. Same comments apply.
we also have a few of these - they’re not fantastic but surely better than nothing.
Paul_H
I think soldering is particularly risky because we're usually closely hunched over the pieces being soldered and flux fumes will rise straight up into our faces. Dave's idea of using a computer fan is really good as it'll pull the fumes away from directly rising into our breathing area. I've got several fans spare so will build one that uses a USB power bank to provide a cordless option.
Renovater
Don't take risks with the fumes from soldering i had problems but luckily i came out. Since that i've bought the ventilator below used for VMC, i rigged up a temporary system using plumbing tubes 100mm for the bends and flexible VMC plastic tubes, not expensive and lasts forever. The input and outputs are 100mm. Look around for the best prices using google search. Colin.
ovener
..or my version made from scrap bits for nowt - takes the same activated carbon filters probably!
paulc
You could just stretch a carbon activated filter mask around the fan . As long as the fan is pulling the air through the mask it will do the same job .
ovener
I had another thought. Actually removing the fumes rather than just filtering and blowing them round the room. Many windows have a trickle vent at the top like this. I wonder if it might be possible to 3D print a new cover with a nozzle on one side, to which could be attached flexible or even rigid conduit or trunking. With the right sort of fan this could blow the fumes outside without freezing/soaking to death with an open window in winter.... it could also be made to clip/unclip easily if required. Possibly a small inline variable speed bathroom fan might do the job better than a computer type, while not being too noisy. Maybe something like this.
12V Exhaust Fan Home Quiet Inline Duct Fan Industrial Fan Bathroom Kitchen Ventilation Fan for Bathroom Kitchen : Amazon.co.uk: DIY & Tools
By the way, that's a very impressive RPM on the label there!
16700 rpm is not excessive for a small permanent magnet dc motor, but I suspect that with a fan attached, it might draw a bit of current.
It would work better in a vacuum (until it overheated...) of course
I'm not sure what the "colour 20mm" means, but hey...
Lawrence Boul
I think there are 3 broad 'solutions' to solder fumes and hazards generally:
  1. Do nothing. For many modelling hazards this is a common approach and for low hazard, low frequency, short duration activities may well be entirely appropriate.
  2. Correctly engineered solutions. Air flow is a science, and removing fumes completely needs to be informed and objectively established. Few hobbyists are willing or able to take such steps.
  3. Half-arsed DIY, based on little but subjective gut feel. Maybe a bit harsh, but many of us do something on grounds of economy, convenience or pragmatism that make us feel better but possibly do not achieve much in actual risk reduction. The quality of solutions will vary. Given that this is the best many of us will get to it's worth being as objective as we can.
The original fan idea is a #3, but if it creates a good airflow and prevents the user snorting concentrated fumes, it's reasonable to assume it mitigates risk, at least somewhat (This seems to be all cheaper commercial units do). I'm a lot more dubious about trying to force contaminated air through small vents. Likewise if filters are employed they need to be the appropriate type.
Debs.
Solder fumes risk duly acknowledged, I just wanted to mention to elephant in the modelling room: solvents!....any of the evaporating petrochemical or inorganic chemical kind; I have found white spirit to be particularly pernicious and harmful (a few seconds that vapour exposure for me, being sufficient to raise two-days of severe migraine) and W.S is clearly present in many other products, ask me how I know!
Many of us have changed to non-solvent based paints, thank goodness for that option, but the presence of aggressive and dangerous volatilates in other modelling adhesives, cleaners and sundry products shouldn't be overlooked; inhaled concentrations can build up rapidly, as vapour often being used close to the face and it passes very easily and rapidly across the air/blood pathways in the lungs.
Potential damage isn't of the "obvious" kind, with damage to bone marrow and multiple organ systems implicated by research into solvent exposure.
I recall attending a lecture at Uni. many years ago, where a Chemist was teaching on the subject of laboratory diligence in medical settings, as an aside he mentioned being horrified by discovering that the contract painters of his campus research laboratory were using solvents to clean the glass surfaces and pipework (prior to painting) and permitting the fumes to fill the room, and drift freely through corridors and into lecture theatres on other floors, to sufficient levels to cause nausea in staff and students.
Extraction fan and ducted discharge externally is good, but better yet perhaps might be only using room temperature evaporating solvents (or products containing them) outside, in the open air.
Debs.
Deano747
Hi Simon, All, I have something similar to the above link and works well with an open window behind to assist with removal. Ok though as long as the wind is in the right direction
