Rewanui (1940 NZR in 1:64 and other distractions)
Lawrence Boul
Does everyone do this?: In every model I make I always find one or two features that I find disproportionately attractive and give me more satisfaction than other bits.
On We375 the safety valves resonate for some reason. Cut from the sprue, dropped into the etched holes and they just sit there perfect (though I see the near one needs to be tweaked straight). It's a silly enlargement, but they still look cool (to me anyway).
Lawrence Boul
Indeed Lawrence, one can spend an inordinate amount of time on something that really can’t be seen. But God and you know it’s there.
I am truly amazed at the castings you are making.
Castings are great when it all goes well. You don't see the tears when it doesn't!
I scratchbuilt a pattern for that pump years ago in 1:64, so I know how tricky that must have been in 2mm. It's the doing, not the seeing though :)
Lawrence Boul
Staying with We375 for another instalment.
The mechanicals are still a little way off, so it's all been about sorting the 'pretty' bits, checking, rechecking and sorting what can be sorted. Everything is either press fit or just placed.
Sand domes were printed and are a bit high. I went with the drawing, but twixt top and bottom castings is a sheetmetal band. I didn't have the measurement for the We, but went with it's parent the B. Unfortunately they are 4" or so too high, but easy fixed. The lids are separate, which is neat as I can fix them slightly askew. But the real benefit is they drain of resin after printing which saves a mess. Almost all the remaining parts are on hand, but their assembly and fitting can wait. There is a lot to go on and it's like a pile of spaghetti, but nothing fit critical.
Pipework and valve gear (Walschaerts) are slightly problematic as I don't have stock of wire, pins and tube appropriate to 9mm. This is slowly being accumulated though.
Sub assemblies like brake hangers are also done. Brake cylinders and cranks are soldered in. Handrails were a gentle press fit in the tanks. These are castings based on the We drawing, so dead right.
If tyres don't arrive, it will be the bogies next. They need tyres too, but the front one is still a bit of a black box. It's a simple looking thing though so should be OK.
The crosshead is a clip together assembly, the slide bars have been touched up with files and the whole thing lapped in with diamond paste. The clip arrangement is a fiddle in 1:64, but a breeze in 9mm. Piston rods still to be added, and the assembly will be honed again after that.
This is the crosshead from behind. The blue part is a press fit and is shaped to positively locate in the main crosshead part. This only works with really accurate castings, and this was pretty simple. If necessary (and as a late step) the blue part can be invisibly solder fixed via the through holes shown here.
Lawrence Boul
Back to Rewanui in 1:64, while 375 awaits some castings:
An earlier post discussed means to model tarpaulins. That exercise got put on hold for a bit as a) I got a bit jaded with the process and b) I had etches on the way that are needed to complete the wagons. But @Overseer came up with the definitive image, so I was always coming back to it.
Here's the first real attempt in undercoat. This is a 2 piece print around about the size of your average open in 4mm (being 1:64 to a more restricted loading gauge). Body + headstocks, and underframe. The W irons are etched and clip in place before a dab of CA secures them. There's spring suspension units to drop in behind as well. A bit of lead (easily disguised here) adds some mass.
There's an etched handbrake lever and a couple of little etch/cast details to complete as well.
The missing lashing rings will be added from wire and the ties added using scale rope. I've had a go at using the correct knots and it is quite feasible. Not that kosher knots were used on the real thing that much if the photos I have are typical. Aside from the printing, there's about 15 minutes worth of effort in this so far.
This one's primarily proof of concept. Now I know how, future examples will be much easier at the digital end (though maybe not that quick as it's a bit involved).
The main practical problem with these is that they are just too good in the fabric department and thus almost impossible to clean up and remove uncured resin. The next version will have those unseen voids filled, which will simplify things.
Lawrence Boul
A brief hiatus on the tarped wagons. @KrustySimplex has provided records to link underframe/axlebox/hornstay/side height (4/5 board) and a few other variations to wagon number and tare. It's beholden on me to get these things correct, so there's been some decisions and sorting to match available decals with tarp candidates. Also reprinting the bodies at a higher resolution to reduce the layering in the tarp as it approaches horizontal.
But while that was happening the courier showed up with the latest castings, which enabled me to fiddle with 375 a bit more. The rods were discussed earlier, but here's a set finished. The leading rod castings has a slight misalignment at the crankpin, but that will be hidden by the con rod.
The centre brass is cast in, but the leading and trailing are separate and can slide in slots in the rod ends. This enables them to be set to the correct length in a jig and then soldered up. Pretty simple to do and a good result.
Lawrence Boul
Castings of late have been noticeably improved. This is all out of my hands and my contractor is not transparent about the details, but I'm not complaining.
NZR engines typically have all the pipework visible and there's quite a bit of it. Things like brake air pipes are 1 1/4", so in 1:64 that's 0.5mm. Not a problem for straight runs, but unions are trickier. I've long had cast unions in the arsenal, but their success rate has been very poor.
But things are improving (mm scale)!
All well and good, but drilling these things out to take wire 'piping' is painful.
I tried a new approach on the last engine, which was to cast these unions with spigots and to use Albion Alloys 0.5mm tube for the pipe. This is a LOT easier and a great saving in broken drills and swear jar contributions.
This is the 9mm version (for 0.9/1mm tube). I need to rework the patterns a bit. While these are very usable there has been a lot of investment failure. There's a fine gap between the hex faces and this resolves in the printing and investment. BUT it's fragile and the inrushing metal snaps off the fine structures resulting in a loss of sharpness and porosity. Easy to fix for the future.
Lawrence Boul
Staying with the theme of castings, this is part of a sprue for a customer.
It's a one off custom casting (1:64) - although all the individual components are from my library. The holes in the top of the Ross 'pop' valve are 0.13mm in diameter and the main body is 1.5mm.
Custom castings from library parts are generally easy (this is priced the same as a standard piece) and the detail levels are high. As mentioned in the last post the main issues at present are that the limitations of the investment are the main constraint on the levels of detail that can be achieved. It is far too easy to create patterns that result in fugitive bits of investment breaking away resulting in blurred detail and unpredictable porosity elsewhere.
The issue is not really one of achievable detail. The detail levels that are possible are generally up to the highest expectations. However it is both tempting and desirable to draw parts exactly. It's easier, maximises the resolution available and, if upscaling, no compromise is carried forward. BUT the reality is that a better result (for a given scale) can be achieved if details are deliberately softened (or more specifically if narrow passages and slots are avoided and edges radiused).
This is all a bit empirical. There is always a tension between a conservative approach that will cast perfectly and an urge for best detail. Currently my patterns lean heavily towards the latter.
Another factor is the number and size of gates. Over the years I've tended to relatively large gates to avoid shorted castings. However large gates mean an easy flow of metal. Reducing the size of gates should slow the metal which may be gentler on the investment and improve the result (provided the casting actually fills). This does seem to work. Shorting is extremely rare and smaller gates do seem to improve things, so I'm moving towards that.
Lawrence Boul
Back onto the big We today.
Main air reservoirs on NZR tank engines are a bit of a pain. Too large and long to cast that nicely, a faff to fabricate, and generally just problematic. Not impossible, just not that easy.
For the We I've gone with a composite approach. The tank has a core of 11/32" K&S tube. On to this are fitted 3 lengths of 3/8" tube for the visible tank. Ends are 3D prints. The brackets are cast and far chunkier than they look having an 11/32" bore and a triangular web that fits a matching slot in the 3D printed side tanks. In these images it's all just press fit.
A minor problem is that they are possibly rather too good - the real thing looked a fair bit mankier than this. A bit of distressing and the odd patch may be called for.
Overseer
Janky is the word my daughters would use. Manky suggests covered in something not very nice, janky is just not very good or a bit rough.
The correct height sand domes look good, as does the rest of it.
Lawrence Boul
Covered in something not very nice sums up the late steam age!
Lawrence Boul
One of things I've found (and that many already know) is that jigs and fixtures to make parts can take far longer to make than the parts themselves.
The 3D printer has helped with this a lot in recent years. Often jigs do not need to be that that strong or durable, or even that accurate. Reproducible is often the major criterion.
With a preference for split frames and a general absence of accurate and quality wheels to a profile that I'm happy with I'm more or less constrained to cast driver centres. I also like the idea of turning the crankpin on the centre (whether cast or as a fitted steel blank). Doing this is not particularly difficult, but it does take time to make fixtures and each wheel design needs something slightly different.
For crankpins it's essential that they all have the same throw and cosmetically ideal if they are centred on the boss. Precise crankthrow is not that important. I've made fixtures from brass etc to do this in a more or less kosher way. But it takes time. Big lumps of metal in the Unimat are not that much fun either.
So previously I've drawn a fixture with a male/female relationship to the centre (a casting from digital print) and printed it. Held in the 3 jaw chuck this was effective for turning crankpins on S scale drivers. Any exact centre issues could be overcome by doing all wheels in a batch without removing the fixture from the chuck.
Recently I've found that printed threads of M4 and up (I haven't tried smaller), seem to be able to hold reasonable loads. The resins I use don't tap all that well as they tend to chip rather than cut, although a tap (if available) may be useful in touching things up. For 375 these observations had me wondering if I could print a fixture that would fit directly to the Unimat headstock (M14x1 - no tap on hand). So here it is (M4 screw with a reduced head retaining the casting in a printed thread). Images are after the required wheels have all been done.
The casting has previously been faced off on the rear.
I'm sure there are caveats on the loads such fixtures can sustain, but the loads from crankpin turning will be relatively small. There was a bit of learning and fiddling to get the threads and fixture right, but this is largely one off. I could probably have used a larger OD and eased the fit with the casting a whisker. Future fittings will be cut and paste.
Is it accurate? It seems to be. I don't have a DTI, but visually things looked good and the cast crankpin blank was pretty true before turning. The wheel was a press fit into the fixture with no slop so they should all be the same at least, and visually they are nicely centred in the boss.
I guess if it's possible to print driver centres, then this sort of thing will be no less accurate.
I'll report back when the chassis is wheeled up as to how well it turns out. In the meantime this was a pretty painless exercise. It is not a universal solution, but there are plenty of cases where this approach might save some time.
Lawrence Boul
Did you helecoil the thread?
Nope. A bit of wear on the M4 makes it look white.
But you could do such things, and probably should if fixture life is an issue.. Next up I need a fixture with a true internally threaded spigot. Likely I'll print a body blank, fit in a brass rod and then turn it all up. I'll be using a short length of 1/4" instead of a chunk of1", and a whole lot less effort.
J_F_S
Brilliant - what a great idea.
Also strikes me that a similar fixture, centered on the axle might be very useful for turning the tyre profile making batch turning a doddle.
Really enjoying this thread; everything in it is first rate.
Lawrence Boul
Thanks!
Turning tyres on the axle has been my approach in 1:64. For 375 some lovely stainless tyres arrived yesterday, so the next job will be fitting them
