Interesting bolt heads Dave, but they used spikes and trenails
As an aside, does anyone know how tall 65lbs bullhead rail is/was? If not, 72lbs would do as a slightly later alternative.
If you're doing separate keys why not go the whole hog and put holes in the chair and supply a selection of Trenails/Spikes/Screws to suit all tastes?![]()
I've still got some of his original chairs lying around somewhere with the dimples.
Maybe Andy May's page on the S Scale web site might be of use
http://www.s-scale.org.uk/rails.htm
Jim.
I should have looked there first.The 1972 catalogue of Thos.W.Ward Ltd (Railway Sidings Division), Albion Works, Sheffield S4 7UL shows 3 different track hammers. Actually it only shows the hammer heads so perhaps you had to supply your own handle? No dimensions given so if anybody's got one in their shed...Dave also forgot to mention the scale keying hammer...![]()
Shown here somewhat larger than 7mm scale as they both scale out at a little over 3mm tall. The GER spike is 0.51mm diameter which probably won't 3d-print very well; likewise the required holes through the chair. The GER trenail is a little larger with the parallel section being 0.73mm diameter but I don't know where you'd get a drill that size and shape to clean out the holes in the chairs. I'll add a few to the sprue; they'll do for the track-gang's toolbox if nothing else!They are LNER boltheads, could be later replacements? They'll just have to wait until later in the week.
.....................For scenic use only of course (but don't tell Peter that!).
All done in AutoCad 2013. Haven't had time to get the rendering and materials to work properly yet but the screendumps of the model view seem to work okay (most of the time).Nice jobhave you done all that in Autocad?
The keys are attached to the sprue at their thick end so can be left on the sprue, inserted and then snapped off.
The acrylic used to print them is virtually transparent. If you don't colour the bits before you drop them you stand very little chance of ever finding them again regardless of the colour of the floor, workbench or baseboard.I have an off white coloured floor so hopefully I'll be able to see the keys![]()
Thank you; but I cheatedYou do a darn sight better in autocad 3d than meI found the transition from 2d really difficult.
. Twenty plus years ago I went to evening classes and dived straight in to a City and Guilds in 3d Autocad leaving out the 2 years of 2d stuff which everybody else was doing! It was all surface modelling (the college couldn't afford the solid modelling bolt-on to v12) but a good grounding nonetheless.
4ft 10spoke wheel for the GER 0-6-0 tanks. It's only taken me 18 months to get a reasonable blend between the spoke and the boss. Now there's the other end of the spoke to blend into the rim, and then the crank boss and balance weights will need spokes blending in as well.
......... and the GER brake blocks.
Definitely the 1 in 6 slip.......... and the GER brake blocks.
should I try something simple like GER brake blocks, a GWR buffer stop or a 1 in 6 single slip?
