Jordan or Plymouth Mad
Mid-Western Thunderer
...and in the same vein....as was beaten into me at school, a king is a ruler and he measures with a rule.
Resistance is futile. You will be assimilated.
Can you get treatment for these symptoms on the NHS?If you have trouble with Ohms Law, here's a couple of helpful ways to remember:
That doesn't look like it would take the power - it may well be running at much lower current for a fan so would probably be a 3W resistor at most. Aside from that it's expensive, 5W resistors are 20p here, although there is p&p so you either find a local electronics store, make it up to enough for free p&p or pay the ebay premium and get the "free" p&p.I think there's some sensible advice in this thread, somewhere....![]()
...telling me the complicated sums is one thing, but actually pointing at what I might need is even more helpful - so thanks in particular to Railwaymaniac.
What about THIS on Ebay. Drops 12v to 7v. Seems to be for PC use, to drop the speed of the fan motor. I wonder if it'd work in a loco....![]()
Failing all that, once you work out what value and wattage you need I'll look in our parts bin and if we have one will send in the post FOCThat doesn't look like it would take the power - it may well be running at much lower current for a fan so would probably be a 3W resistor at most. Aside from that it's expensive, 5W resistors are 20p here, although there is p&p so you either find a local electronics store, make it up to enough for free p&p or pay the ebay premium and get the "free" p&p.
.Likewise - if it's not too urgent I can always add a few more bits and pieces to my next order with Rapid. I usually order enough to get free postage (latest batch of MERG-CBUS kits was £500). Alternatively I live just round the corner to CPC so can collect anything from the counter if required.Failing all that, once you work out what value and wattage you need I'll look in our parts bin and if we have one will send in the post FOC.
FWIW the formula was given back in post #4![]()
