AndyB
I can recommend an excellent osteopath....... whilst I give my back a break![]()
He's sorted all of my family out at various times - from 6 month old daughter to 48 year old me.
Andy
Time to design a rail bender for the next step.
I managed to get all the planks cut to length and screwed down![]()
No need for another high maintenance hobby GeoffThat's a very neat piece of work Steve, are you going to fit a hot tub in the centre to help ease your aching back ?
I'll settle for using the bath!Thanks Andy, but I have enough medical attention on my back alreadyI can recommend an excellent osteopath....
Andy
Six evenings of work highlights how much strength I've lost over the last years as a result of the sciatica - all I can do is exercise and use it to gain back what I've lost.Pretty much Jim. I suspect that a better job would come from having a wheel around each ballrace, the circumference of which fits in between the head and foot of the rail so the bending is done on the web as well as the head / foot. That will also help to keep the rail in alignment through the rollers and not induce any vertical twist. I'll keep you updatedSteve,
I've been thinking about that for the track on my oval. I've got one of these combination bender/guillotine/roller machines and I could probably machine shallow slots at the ends of the rolls to locate the bullhead rail to bend it. I'll have to have a trial with a bit of rail and see if it's a go-er. Otherwise I'll copy what you do - something like three ball races, one of them being moveable??
Jim.
I'll take that as a compliment for a test track DaveIt all rather looks like Teutonic engineering.
Its not very 'garden' but my focus for this one is in the locos, the stock and the material choices. It all helps steer me in the choices for future projects...I first read that as Tectonic engineering. I should concentrate more, but it could explain Steve's back problems or maybe theres a secret plan for the next big project.It all rather looks like Teutonic engineering.
... and beers naturally.
). Because I'm trying to pinch every mm possible, I set up a datum line for the inside rail edge from the garage wall and then used various bits of wood to create a trammel with which I can accurately place the curves. I cross checked it numerous times, making sure that there would be no restriction within 100 mm of the outside rail, then worked out where the turnout is going to sit so I could build forward from that.
DefinitelyChristening run after the AGM maybe?
I got there in the end though after some cursing and a few attempts. The wedges are a pretty neat design with markings on the surface to indicate the level of raising from the baseboard surface.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
